uhsdr_dev:uhsdrbuild
  • UHSDR toolchain installed, see here
  • Goto https://github.com/df8oe/UHSDR and click button „clone or download“
  • Unpack the downloaded .zip file on your hard disk. Do not change the name, do not change the internal zip structure
  • In Eclipse, choose „File→Import“.
  • .. then choose „General→Existing Projects into Workspace“.
  • Then choose the folder „mchf-eclipse in the path where you just downloaded the zip file as „root-directory“
  • The project is now recognized and can be imported
  • Project → Build Configurations → Set Active → DebugLibOVI40 (OVI49 DSP Library (STM32F7))
  • Click on the „hammer“ in the tool bar
  • Watch Console window in Eclipse - if all ok console output ends with “ … Build finished …„
  • Project → Build Configurations → Set Active → DebugOVI40 (OVI40 Firmware (STM32F7) …)
  • User guide can be found here.
  • Profiling is described here
01.02.2018 23:12 · df9ts_user
  • uhsdr_dev/uhsdrbuild.1518070089.txt.gz
  • Zuletzt geändert: 08.02.2018 06:08
  • von df9ts
