Show pagesourceOld revisionsBacklinksExport to PDFBack to top Share via Share via... Twitter LinkedIn Facebook Pinterest Telegram WhatsApp Yammer RedditRecent ChangesSend via e-MailPrintPermalink × Table of Contents UHSDR Firmware DfuSe Firmware upgrade Preconditions Procedure Further Reading USB Stick Firmware upgrade Preconditions Procedure Further Reading ST-Link/V2 Firmware upgrade Preconditions Procedure Further Reading Discussion review english Note: Attention: Work in progress - page under construction UHSDR Firmware There are two standard options to load new firmware versions onto a working UHSDR boot loader: DfuSe Tool USB Stick ST-Link/V2 debug adapter can also be used to download new firmware DfuSe Firmware upgrade Preconditions Download latest fw-40SDR.dfu firmware from here. Install ST-Micro DeFuse Tool: http://www.st.com/en/development-tools/stsw-stm32080.html Connect PC with OVI40 UI via USB - to - MiniUSB cable. Use MiniUSB plug on OVI40 UI ST-Micro DFuse SW installed on PC and running, USB drivers installed, OVI40 UI recognized by PC Procedure Press switch “band +” and keep pressed supply +5V to OVI40 UI (JP1 pin 28) keep pressing “band +” switch until “DFU upgrade mode” appears on LCD screen. You may release the “band + ” switch then Use DfuSe Tool to load new firmware. Use the “Choose button marked in picture to select new firmware to upload, not the other one. Then use Upload and Verify button, then quit DfuSe Tool Reboot Test new firmwre Further Reading ST-Micro DFuse Tool Beschreibung USB Stick Firmware upgrade Preconditions Download latest fw-40SDR.bin firmware from here. Format USB-Stick with FAT or FAT32 file partition. Make sure - just in case - that USB-stick is otherwise empty Copy .bin file to stick. Make sure it is copied as file, not just a link / short-cut Recent UHSDR boot loader installed and working Procedure Supply +8V on JP1 pin 29 - to pwer USB stick Push and - important - hold switch “BAND -” Supply +5V on JP1 pin 28 - this starts the boot loader Wait until “USB drive mode” is displayed on LCD screen, then release “band -” switch insert USB stick into large USB port of OVI40 UI Wait for FW upload to finish Remove +5V, then apply again to reboot OVI40 UI. Further Reading https://github.com/df8oe/UHSDR/blob/81dd4afae1a52103b2f1824cba34e2ff35e805ea/mchf-eclipse/useful_manuals/bootloader_doc.md https://github.com/df8oe/UHSDR/wiki/Firmware-Upgrades ST-Link/V2 Firmware upgrade Preconditions Download latest fw-40SDR.bin firmware from here. Connect ST-Link/V2 with OVI40 UI and with PC. Start STM32 ST-Link Utility on PC Recent UHSDR boot loader installed and working OVI40 UI powered up Procedure In ST-Link Utility: Target→Connect In ST-Link Utility: Target→Program and Verify Start address 0x08010000 Enter file path of .bin file to program Select verify while programming Select “reset after programming” Hit “Start” to program device After successful programming the UHSDR FW should start Further Reading You could leave a comment if you were logged in. en/uhsdr/uhsdrfw.txt Last modified: 06.02.2018 10:08by df9ts_user
