Show pagesourceOld revisionsBacklinksExport to PDFBack to top Share via Share via... Twitter LinkedIn Facebook Pinterest Telegram WhatsApp Yammer RedditRecent ChangesSend via e-MailPrintPermalink × Table of Contents UHSDR development - Build using eclipse Preconditions, Assumptions, Scope Pull UHSDR source from Github, import into eclipse Build UHSDR using eclipse Download new firmware .bin to OVI40 UI Generate .dfu file from .bin file Eclipse user guide Debug, tracing, real-time diagnostics Further reading Discussion english review Note: Attention: Work in progress - page under construction UHSDR development - Build using eclipse Preconditions, Assumptions, Scope UHSDR toolchain installed, see here Pull UHSDR source from Github, import into eclipse Goto https://github.com/df8oe/UHSDR and click button “clone or download” Unpack the downloaded .zip file on your hard disk. Do not change the name, do not change the internal zip structure In Eclipse, choose “File→Import”. .. then choose “General→Existing Projects into Workspace”. Then choose the folder “mchf-eclipse in the path where you just downloaded the zip file as “root-directory” The project is now recognized and can be imported Build UHSDR using eclipse Project → Build Configurations → Set Active → DebugLibOVI40 (OVI49 DSP Library (STM32F7)) Click on the “hammer” in the tool bar Watch Console window in Eclipse - if all ok console output ends with ” … Build finished …“ Project → Build Configurations → Set Active → DebugOVI40 (OVI40 Firmware (STM32F7) …) Click on the “hammer” in the tool bar Watch Console window in Eclipse - if all ok console output ends with ” … Build finished …“ Newly built binary fw-ovi40.bin can be found in the eclipse project explorer (left sidebar): mchf-eclipse → DebugOVI40 → fw-ovi40.bin Download new firmware .bin to OVI40 UI Please refer to https://www.amateurfunk-sulingen.de/wiki/doku.php?id=en:uhsdr:uhsdrfw#st-link_v2_firmware_upgrade UHSDR FW build should run. Hit switch “Menu”, then select “System Info” and “Build”. Check the build date and time corresponds to your compile time in eclipse approximatelly Generate .dfu file from .bin file With .bin file the FW can be installed via USB stick of ST-Link/V2 adapter. You may want to create a dfu file from the bin file so that the DfuSE FW install method can be used. Section 4.2.1 of STM manual UM0412 describes step-by-step the generation of a .dfu file. The ST-Micro UM0412 manual on DfuSe can be found here. Original source is this. Eclipse user guide User guide can be found here. Profiling is described here This covers basic usage as well as advanced tools such as profiling and others. Debug, tracing, real-time diagnostics nice summary of Cortex M tools here OpenOCD & Eclipse debug step-by-step instructions AN4989 Application note STM32 microcontroller debug toolbox Concurrent use of ST-Link debugger and SWO Viewer not possible, see here - but this link states Eclipse support in debugger for SWO? J-Link Debug Probe here Further reading https://www.amateurfunk-sulingen.de/forum/index.php?board=15;action=display;threadid=313;start=0 https://www.amateurfunk-sulingen.de/forum/index.php?board=15;action=display;threadid=263 SWV and SWO and Eclipse explaind here You could leave a comment if you were logged in. en/uhsdr_dev/uhsdrbuild.txt Last modified: 15.02.2018 00:03by df9ts_user
