Show pagesourceOld revisionsBacklinksExport to PDFBack to top Share via Share via... Twitter LinkedIn Facebook Pinterest Telegram WhatsApp Yammer RedditRecent ChangesSend via e-MailPrintPermalink × Table of Contents Ordering OVI40 UI board and Display module Discussion english publish Ordering OVI40 UI board and Display module OVI40 UI board and display board can be ordered here The kits will require SMD soldering. For the OVI40 UI board there are 3 order options: bare PCBs - you provide the components yourself kit - containing PCBs and all required components soldered and tested UI boards, ready to use The display board is offered as soldered and tested module, ready to plug into OVI40 board. The rf board is still under development and cannot be ordered at this moment. Please note that mcHF RF boards upto and including V0.6 are compatible with OVI40 Ui board and can be used also. You could leave a comment if you were logged in. en/ovi40order/order.txt Last modified: 27.01.2018 07:42by df9ts_user
