Show pagesourceOld revisionsBacklinksExport to PDFBack to top Share via Share via... Twitter LinkedIn Facebook Pinterest Telegram WhatsApp Yammer RedditRecent ChangesSend via e-MailPrintPermalink × Table of Contents Errata for OVI40 UI V1.8 Batch 1 kit delivery In Kit Bag 1 In Kit Bag 2: In Kit Bag 4: Kit Bag 5: Other Discussion english publish Errata for OVI40 UI V1.8 Batch 1 kit delivery Source: https://www.amateurfunk-sulingen.de/forum/index.php?board=18;action=display;threadid=935;start=0 In Kit Bag 1 3.5 mm Stereo Connectors J1, J2, J3 plastic noses won’t fit the PCB holes Cut the plastic noses or use fitting socket Lumberg 1503-7 (Reichelt LUM 1503-07, Conrad 738788) The 470 nF capacitors have size 0805, however size 0603 is required according to PCB Layout and BoM. Can still be soldered in In Kit Bag 2: Mini-USB socket J11 is “Type A” but “Type B” is required. Use correct socket, e.g. Buerklin 72F2280 In Kit Bag 4: The 2.2 uF capacitors have size 0805, but size 0603 is required in BoM and PCB Layout. Can still be soldered in. Kit Bag 5: The 1 uF capacitors are 1206, but 0603 is required according to BoM. Need to get correct size, e.g. 0603, e.g. Buerklin 75D5307 The capacitors (8,2pF-10pF) are 0402 but should be 0603. Can still be soldered in. Other R2, R6, R7, R10-12,R15, R25, R40 have 0603 footprint in BOM but on PCB we have 0805. Can still be soldered in C100 is marked “COO” (letter “O” instead of digit “0”) instead in schematics (so can’t be found with Acrobat Reader in schematic You could leave a comment if you were logged in. en/ovi40build/ovi40_batch1uiboarderrata.txt Last modified: 07.02.2018 05:59by df9ts_user
