Show pagesourceOld revisionsBacklinksExport to PDFBack to top Share via Share via... Twitter LinkedIn Facebook Pinterest Telegram WhatsApp Yammer RedditRecent ChangesSend via e-MailPrintPermalink × Table of Contents UHSDR Operations Reset all settings to default Discussion english stub UHSDR Operations Reset all settings to default Switch off OVI40UI Press and hold push buttons F1 F3 F5 Switch on OVI40, wait for text message, release F1 F3 F5 Press simultaneously Band+ and Band- buttons to confirm resetting of settings When UHSDR has bootet up long-press System Menu (F1 button) to save values Hint: If you just want to play around with default setting without loosing your own configuration: do NOT press MENU long do NOT switch off via power button because that stores active settings to EEPROM - just pull off power supply. You could leave a comment if you were logged in. en/operations/uhsdrops.txt Last modified: 17.02.2018 11:43by df9ts
