Warning: This page under construction - no guarantee what soever that content is correct, fit for use. Use at your own peril
Pull UHSDR source from Github, import into eclipse
- Goto https://github.com/df8oe/UHSDR and click button “clone or download”
- Unpack the downloaded .zip file on your hard disk. Do not change the name, do not change the internal zip structure
Build UHSDR using eclipse
- Project → Build Configurations → Set Active → DebugLibOVI40 (OVI49 DSP Library (STM32F7))
- Click on the “hammer” in the tool bar
- Watch Console window in Eclipse - if all ok console output ends with ” … Build finished …“
- Project → Build Configurations → Set Active → DebugOVI40 (OVI40 Firmware (STM32F7) …)
Download new firmwar .bin to OVI40 UI
- UHSDR FW build should run.
- Hit switch “Menu”, then select “System Info” and “Build”. Check the build date and time corresponds to your compile time in eclipse approximatelly
Generate .dfu file from .bin file
