UI-Platine:
BOM OVI40-SDR UI V1.7 | 24-09-2017 | DF8OE | Distributor | |||||||||
Part | Value | Description | Package | Amount | FARNELL | Price | Reichelt | Price | Mouser | Price | Digikey | Price |
IC1 /IC12 | WM8731 | Audio CODEC WM8731 | SSOP28 | 2 | 238-WM8731SEDS/V | WM8731SEDS/RVCT-ND | 3,63 | |||||
or Audio CODEC TLV320AIC23BPWG4 | SSOP28 | 2 | 120-7297 | 9,25 | ||||||||
IC2 | LM4952TS | TI Stereo Audio PA | LM4952 | 1 | 100-8028 | 3,72 | 926-LM4952TS/NOPB | LM4952TS/NOPB-ND | 3,06 | |||
IC3 | LP5907_Q1 | TI low noise LDO 3,3 Volt | SOT23-5 | 1 | 249-2304 | 0,654 | 595-LP5907QMFX-3.3Q1 | 296-38557-1-ND | 0,47 | |||
IC4 | STM32F76X_ZIT6 | MCU | LQFP144 | 1 | 253-5499 | 12,84 | 511-STM32F767ZIT6 | 497-16521-ND | 13,26 | |||
IC5 | ASTX-H11 | 16 MHz TCXO 2,5ppm 3,2 x 2,5 mm | TCXO_32X25 | 1 | 815-ASTXH1116T | 535-12044-1-ND | 2,84 | |||||
IC6 | KA78RM33R | 3,3 Volt LDO | DPAK | 1 | 245-1041 | 0,681 | TS 2940 CP33 | 821-TS2940CP33 | ||||
IC7 | AT24CM02 | I2C EEPROM | SO08 | 1 | 24LC1026_ISN | 579-24LC1026I/SN | AT24CM02-SSHM-B-ND | 1,89 | ||||
IC8 | NCP5501DT50G | 5,0 Volt LDO | DPAK | 1 | 170-3369 | 0,602 | TS 2940 CP50 | 821-TS2940CP50 | ||||
Q1 | 32,768 kHz | QCM-315_SMD | CM315 | 1 | 695-CM315D-32.7KEZFT | 300-8813-1-ND | 0,6 | |||||
T3 | BC857 | PNP Transistor | SOT23 | 1 | 179-8067 | 0,02 | BC 857C SMD | 0,034 | 771-BC857CW115 | |||
D5 | BAV70 | Double Diode | SOT23 | 2 | 267-7467 | 0,031 | BAV 70 SMD | 0,034 | 512-BAV70 | |||
D6 | BAV70 | Double Diode | SOT23 | . | ||||||||
D7 | BAS85 | Schottky barrier diode | SOD80C | 3 | 146-9394 | 0,23 | BAS 85 SMD | 0,034 | 771-BAS85135 | |||
D8 | BAS85 | Schottky barrier diode | SOD80C | . | ||||||||
D9 | BAS85 | Schottky barrier diode | SOD80C | . | ||||||||
D1 | green | LED | LED_3MM | 1 | 276-4976 | 0,409 | LED 3MM ST GN | |||||
D2 | red | LED | LED_3MM | 1 | 276-4977 | 0,361 | LED 3MM ST RT | |||||
D3 | blue | LED | LED_3MM | 1 | 276-4975 | 0,443 | LED 3MM ST BL | |||||
BAT1-HOLDER | Battery Holder CR2032 | 1 | 188-5903 | 2,98 | BU2032-1-ND | 0,66 | ||||||
BAT1 | CR2032P_L | Lithium Battery 3,0Volt | CR_2032_H | 1 | CR 2032P-H | |||||||
X1 | PN87520-S | USB Plug HOST | PN87520-S | 1 | 117-7883 | 0,81 | USB AW | 0,2 | ||||
J11 | MINI-USB_B | USB Plug DFU | MINI-USB_B | 1 | 211-2367 | 0,561 | USB BWM SMD | 0,28 | ||||
LCD1 | HY32D | 3,2 Zoll LCD ILI9325 | HY32D_UHSDR_MOD | 1 | ||||||||
L1 | 47uH | L_SMD1005 | L1005 | 3 | 221-5655 | 0,13 | MLZ2012M470WT000 | 0,12 | ||||
L2 | 47uH | L_SMD1005 | L1005 | . | ||||||||
L3 | 47uH | L_SMD1005 | L1005 | . | ||||||||
R1 | 47k | SMD Resistor TK50 | 0805 | 6 | SMD-0805 47k | 0,02 | ||||||
R1A | 100R | SMD Resistor TK50 | 0603 | 13 | SMD-0603 100 | 0,03 | ||||||
R1B | 0R | SMD Resistor TK50 | 0603 | 3 | SMD-0603 0 | 0,03 | ||||||
R2 | 1k | SMD Resistor TK50 | 0603 | 7 | SMD-0603 1,0k | 0,03 | ||||||
R3 | 100R | SMD Resistor TK50 | 0603 | . | ||||||||
R4 | 1k | SMD Resistor TK50 | 0603 | . | ||||||||
R4B1 | 2R2 | SMD Resistor TK50 | 1206 | 4 | SMD ¼W 2,2 | 0,03 | ||||||
R4D | 2R2 | SMD Resistor TK50 | 1206 | . | ||||||||
R5 | 0R | SMD Resistor TK50 | 0603 | . | ||||||||
R6 | 1k | SMD Resistor TK50 | 0603 | . | ||||||||
R7 | 1k | SMD Resistor TK50 | 0603 | . | ||||||||
R8 | 100R | SMD Resistor TK50 | 0603 | . | ||||||||
R9 | 4k7 | SMD Resistor TK50 | 0805 | 4 | SMD-0805 4,7k | 0,02 | ||||||
R10 | 4k7 | SMD Resistor TK50 | 0603 | 1 | SMD-0603 4,7k | 0,02 | ||||||
R11 | 4k7 | SMD Resistor TK50 | 0805 | . | ||||||||
R12 | 4k7 | SMD Resistor TK50 | 0805 | . | ||||||||
R13 | 47R | SMD Resistor TK50 | 0603 | 7 | SMD-0603 47 | 0,03 | ||||||
R14 | 47R | SMD Resistor TK50 | 0603 | . | ||||||||
R15 | 1k | SMD Resistor TK50 | 0603 | . | ||||||||
R16 | 100R | SMD Resistor TK50 | 0603 | . | ||||||||
R17 | 100R | SMD Resistor TK50 | 0603 | . | ||||||||
R18 | 100R | SMD Resistor TK50 | 0603 | . | ||||||||
R19 | 100R | SMD Resistor TK50 | 0603 | . | ||||||||
R20 | 100R | SMD Resistor TK50 | 0603 | . | ||||||||
R21 | 47R | SMD Resistor TK50 | 0603 | . | ||||||||
R22 | 47R | SMD Resistor TK50 | 0603 | . | ||||||||
R23 | 0R | SMD Resistor TK50 | 0805 | 8 | SMD-0805 0 | 0,02 | ||||||
R24 | 680R | SMD Resistor TK50 | 0805 | 4 | SMD-0805 680 | 0,02 | ||||||
R25 | 4k7 | SMD Resistor TK50 | 0805 | . | ||||||||
R26 | 100R | SMD Resistor TK50 | 0603 | . | ||||||||
R27 | 100R | SMD Resistor TK50 | 0603 | . | ||||||||
R28 | 100R | SMD Resistor TK50 | 0603 | . | ||||||||
R29 | 1k | SMD Resistor TK50 | 0603 | . | ||||||||
R30 | 0R | SMD Resistor TK50 | 0805 | . | ||||||||
R31 | 0R | SMD Resistor TK50 | 0805 | . | ||||||||
R32 | 0R | SMD Resistor TK50 | 0805 | . | ||||||||
R33 | 100R | SMD Resistor TK50 | 0603 | . | ||||||||
R34 | 100R | SMD Resistor TK50 | 0603 | . | ||||||||
R35A | 4R7 | SMD Resistor TK50 | 1206 | 1 | SMD ¼W 4,7 | 0,03 | ||||||
R36 | 680R | SMD Resistor TK50 | 0805 | . | ||||||||
R37 | 680R | SMD Resistor TK50 | 0805 | . | ||||||||
R40 | 1k | SMD Resistor TK50 | 0603 | . | ||||||||
R41 | 47R | SMD Resistor TK50 | 0603 | . | ||||||||
R45 | 2R2 | SMD Resistor TK50 | 1206 | . | ||||||||
R46 | 2R2 | SMD Resistor TK50 | 1206 | . | ||||||||
R47 | 47R | SMD Resistor TK50 | 0603 | . | ||||||||
R48 | 47R | SMD Resistor TK50 | 0603 | . | ||||||||
R101 | 0R | SMD Resistor TK50 | 0603 | . | ||||||||
R108 | 0R | SMD Resistor TK50 | 0805 | . | ||||||||
R110 | 0R | SMD Resistor TK50 | 0805 | . | ||||||||
R112 | 0R | SMD Resistor TK50 | 0805 | . | ||||||||
R114 | 0R | SMD Resistor TK50 | 0805 | . | ||||||||
R116 | 680R | SMD Resistor TK50 | 0805 | . | ||||||||
R120 | 47k | SMD Resistor TK50 | 0805 | . | ||||||||
R121 | 47k | SMD Resistor TK50 | 0805 | . | ||||||||
R122 | 47k | SMD Resistor TK50 | 0805 | . | ||||||||
R123 | 47k | SMD Resistor TK50 | 0805 | . | ||||||||
R124 | 47k | SMD Resistor TK50 | 0805 | . | ||||||||
C1 | 1nF | SMD Chip Capacitor NP0/COG | 0603 | 10 | KEM C0G0603 1,0N | 0,01 | ||||||
C1A | 1nF | SMD Chip Capacitor NP0/COG | 0603 | . | ||||||||
C1B | 1nF | SMD Chip Capacitor NP0/COG | 0603 | . | ||||||||
C1C | 1nF | SMD Chip Capacitor NP0/COG | 0603 | . | ||||||||
C1D | 1nF | SMD Chip Capacitor NP0/COG | 0603 | . | ||||||||
C2 | 1nF | SMD Chip Capacitor NP0/COG | 0603 | . | ||||||||
C3 | 1nF | SMD Chip Capacitor NP0/COG | 0603 | . | ||||||||
C4 | 1nF | SMD Chip Capacitor NP0/COG | 0603 | . | ||||||||
C5 | 220uF | SMD Tantal-ELKO 10V | TA-C | 5 | TAJ 6032 220/10 | 0,46 | ||||||
C6 | 220uF | SMD Tantal-ELKO 10V | TA-C | . | ||||||||
C7 | 470nF | SMD Chip Capacitor NP0/COG | 0603 | 4 | NPO 0603 CD 470N | 0,04 | ||||||
C8 | 470nF | SMD Chip Capacitor NP0/COG | 0603 | . | ||||||||
C9 | 220uF | SMD Alu-Elko 16V low ESR | E_SMD_0608 | 6 | VF 220/16 P-D8 | 0,3 | ||||||
C10 | 100nF | SMD Chip Capacitor X7R | 0603 | 63 | X7R 0603FCF 100N | 0,04 | ||||||
C11 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C12 | 10uF | SMD Tantal-ELKO 16V | TA-B 3,5 x 2,8 | 9 | T494B 10U 16 | 0,51 | ||||||
C13 | 10uF | SMD Tantal-ELKO 16V | TA-B 3,5 x 2,8 | . | ||||||||
C14 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C15 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C16 | 10uF | SMD Tantal-ELKO 16V | TA-B 3,5 x 2,8 | . | ||||||||
C17 | 10uF | SMD Tantal-ELKO 16V | TA-B 3,5 x 2,8 | . | ||||||||
C18 | 1uF | SMD Chip Capacitor NP0/COG | 0603 | 8 | NPO 0603 CE 1,0U | 0,04 | ||||||
C19 | 1uF | SMD Chip Capacitor NP0/COG | 0603 | . | ||||||||
C20 | 470nF | SMD Chip Capacitor NP0/COG | 0603 | . | ||||||||
C21 | 1nF | SMD Chip Capacitor NP0/COG | 0603 | . | ||||||||
C22 | 10uF | SMD Tantal-ELKO 16V | TA-B 3,5 x 2,8 | . | ||||||||
C23 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C24 | 4.7uF | SMD Tantal-ELKO | TA-A 3,2 x 1,6 | 1 | T491A 4,7U 16 | 0,04 | ||||||
C25 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C26 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C27 | 220pF | SMD Chip Capacitor NP0/COG | 0805 | 2 | NPO 0805 BG 220P | 0,04 | ||||||
C28 | 220pF | SMD Chip Capacitor NP0/COG | 0805 | . | ||||||||
C29 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C30 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C31 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C32 | 220uF | SMD Alu-Elko 16V low ESR | E_SMD_0608 | . | ||||||||
C32B | 220uF | SMD Alu-Elko 16V low ESR | E_SMD_0608 | . | ||||||||
C33 | 220uF | SMD Alu-Elko 16V low ESR | E_SMD_0608 | . | ||||||||
C34 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C35 | 220uF | SMD Alu-Elko 16V low ESR | E_SMD_0608 | . | ||||||||
C36 | 1nF | SMD Chip Capacitor NP0/COG | 0805 | 10 | NPO G0805 1,0N | 0,04 | ||||||
C37 | 1nF | SMD Chip Capacitor NP0/COG | 0805 | . | ||||||||
C38 | 1nF | SMD Chip Capacitor NP0/COG | 0603 | . | ||||||||
C39 | 220uF | SMD Tantal-ELKO 10V | TA-C | . | ||||||||
C40 | 470nF | SMD Chip Capacitor NP0/COG | 0603 | . | ||||||||
C41 | 10uF | SMD Tantal-ELKO 16V | TA-B 3,5 x 2,8 | . | ||||||||
C42 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C43 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C44 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C45 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C46 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C47 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C48 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C49 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C50 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C51 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C52 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C53 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C54 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C55 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C56 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C57 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C58 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C59 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C60 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C61 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C62 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C63 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C64 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C65 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C66 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C67 | 1nF | SMD Chip Capacitor NP0/COG | 0805 | . | ||||||||
C68 | 1nF | SMD Chip Capacitor NP0/COG | 0805 | . | ||||||||
C69 | 1nF | SMD Chip Capacitor NP0/COG | 0805 | . | ||||||||
C70 | 1nF | SMD Chip Capacitor NP0/COG | 0805 | . | ||||||||
C71 | 1nF | SMD Chip Capacitor NP0/COG | 0805 | . | ||||||||
C72 | 1nF | SMD Chip Capacitor NP0/COG | 0805 | . | ||||||||
C73 | 1nF | SMD Chip Capacitor NP0/COG | 0805 | . | ||||||||
C74 | 1nF | SMD Chip Capacitor NP0/COG | 0805 | . | ||||||||
C74A | 220uF | SMD Tantal-ELKO 10V | TA-C | . | ||||||||
C75 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C76 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C77 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C78 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C79 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C80 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C81 | 1uF | SMD Chip Capacitor NP0/COG | 0603 | . | ||||||||
C82 | 1uF | SMD Chip Capacitor NP0/COG | 0603 | . | ||||||||
C83 | 1uF | SMD Chip Capacitor NP0/COG | 0603 | . | ||||||||
C84 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C85 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C86 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C87 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C88 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C89 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C90 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C91 | 2,2uF | SMD Chip Capacitor NP0/COG | 0603 | 2 | NPO 0603 CC 2,2U | 0,04 | ||||||
C92 | 2,2uF | SMD Chip Capacitor NP0/COG | 0603 | . | ||||||||
C93 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C94 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C95 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C96 | 220uF | SMD Alu-Elko 16V low ESR | E_SMD_0608 | . | ||||||||
C97 | 10uF | SMD Tantal-ELKO 16V | TA-B 3,5 x 2,8 | . | ||||||||
C98 | 10uF | SMD Tantal-ELKO 16V | TA-B 3,5 x 2,8 | . | ||||||||
C99 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C101 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C102 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C104 | 1uF | SMD Chip Capacitor NP0/COG | 0603 | . | ||||||||
C105 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C106 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C107 | 1uF | SMD Chip Capacitor NP0/COG | 0603 | . | ||||||||
C108 | 1uF | SMD Chip Capacitor NP0/COG | 0603 | . | ||||||||
C109 | 220pF | SMD Chip Capacitor NP0/COG | 0603 | 1 | NPO 0603AAF 220P | 0,04 | ||||||
C111 | 10uF | SMD Tantal-ELKO 16V | TA-B 3,5 x 2,8 | . | ||||||||
C112 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C120 | 220uF | SMD Tantal-ELKO 10V | TA-C | . | ||||||||
C121 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C122 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C123 | 100nF | SMD Chip Capacitor X7R | 0603 | . | ||||||||
C124 | 8,2pF – 10pF | SMD Chip Capacitor | 0603 | 2 | NPO-G0603 10P | 0,04 | ||||||
C125 | 8,2pF – 10pF | SMD Chip Capacitor | 0603 | . | ||||||||
S1 | G3 | SMD Pushbutton KSC941J | 18 | 243-5157 | 0,64 | CKN10433CT-ND | 0,55 | |||||
S2 | G2 | SMD Pushbutton KSC941J | . | |||||||||
S3 | M2 | SMD Pushbutton KSC941J | . | |||||||||
S4 | BM | SMD Pushbutton KSC941J | . | |||||||||
S5 | G4 | SMD Pushbutton KSC941J | . | |||||||||
S6 | M3 | SMD Pushbutton KSC941J | . | |||||||||
S7 | SM | SMD Pushbutton KSC941J | . | |||||||||
S8 | SP | SMD Pushbutton KSC941J | . | |||||||||
S9 | M1 | SMD Pushbutton KSC941J | . | |||||||||
S10 | F3 | SMD Pushbutton KSC941J | . | |||||||||
S11 | F1 | SMD Pushbutton KSC941J | . | |||||||||
S12 | F2 | SMD Pushbutton KSC941J | . | |||||||||
S13 | F4 | SMD Pushbutton KSC941J | . | |||||||||
S14 | BP | SMD Pushbutton KSC941J | . | |||||||||
S15 | F5 | SMD Pushbutton KSC941J | . | |||||||||
S16 | G1 | SMD Pushbutton KSC941J | . | |||||||||
S17 | Power | SMD Pushbutton KSC941J | . | |||||||||
S18 | not assigned yet | SMD Pushbutton KSC941J | . | |||||||||
J1 | 1503_07 | Audio Plug 3,5mm | 1503_07 | 3 | 121-7016 | 2,26 | LUM 1503-07 | 0,59 | ||||
J2 | 1503_07 | Audio Plug 3,5mm | 1503_07 | . | ||||||||
J3 | 1503_07 | Audio Plug 3,5mm | 1503_07 | . | ||||||||
J4 | 1503_09 | Audio Plug w. 2 switches | 1503_09 | 1 | 124-3244 | 2,04 | LUM 1503-09 | 0,99 | ||||
E1 | EC12E_SW | Alps Encoder with push function | ALPS_EC12E_SW | 4 | 152-0813 | 1,86 | STEC12E08 | 2,1 | ||||
E2 | EC12E_SW | Alps Encoder with push function | ALPS_EC12E_SW | . | ||||||||
E3 | EC12E_SW | Alps Encoder with push function | ALPS_EC12E_SW | . | ||||||||
E4 | EC12E_SW | Alps Encoder with push function | ALPS_EC12E_SW | . | ||||||||
Button Cap | Cap grey | BTNKSC920 | 4 | CKN10429-ND | 0,27 | |||||||
Button Cap | Cap red | BTNKSC940 | 2 | CKN10428-ND | 0,27 | |||||||
Button Cap | Cap black | BTNKSC990 | 2 | CKN10426-ND | 0,27 | |||||||
Button Cap | Cap white | BTNKSC980 | 10 | CKN10427-ND | 0,27 | |||||||
JP1 | 30 Pin Board to Board | Pinheader-1×30 | 1×30 | 1 | 3x 40-polig | |||||||
JP2 | 25 Pin Board to Board | Pinheader-1×25 | 1×25 | 1 | ||||||||
JP3 | 6 Pin Board to Board | Pinheader-1×06 | 1×06 | 4 | ||||||||
P1 | SW_12V | Pinheader-1×02 | 1×02 | 6 | ||||||||
P2 | Speaker left | Pinheader-1×02 | 1×02 | . | ||||||||
P7 | Speaker right | Pinheader-1×02 | 1×02 | . | ||||||||
P6 | DFU mode Jumper | Pinheader-1×02 | 1×02 | . | ||||||||
JP8 | DEBUG | Pinheader-1×06 | 1×06 | . | ||||||||
JP17 | short S17 | Pinheader-1×02 | 1×02 | . | ||||||||
JP5 | ext. USB Host | Pinheader-1×04 | 1×04 | 2 | ||||||||
JP6 | ext. USB DFU | Pinheader-1×04 | 1×04 | . | ||||||||
JP4 | ext. Audio | Pinheader-1×06 | 1×06 | . | ||||||||
JP7 | ext. Audio | Pinheader-1×06 | 1×06 | . | ||||||||
P3 | alternative Bridge Vbat | Pinheader-1×02 | 1×02 | . | ||||||||
LCD1 | Pinheader-2×17 | 2×17 | 1 | |||||||||
LCD/PCB | Holeheader low profile 2×17 | BL 2X17G 2,54 | 1 | |||||||||
BU2 | MOLEX_SD_49225-0821 | MICROSD_Cardreader | Molex 503182-1853 | 1 | 176-4375 | 1,99 | HR1942CT-ND | 2,05 | ||||
optional parts | ||||||||||||
D4 | SS16SMA | Vishay General Semiconductor SS16 | DIODE_SMA | |||||||||
IC9 | CY15B104Q | SPI FRAM | SO08 | |||||||||
IC11 | SST25VF04B | SPI FLASH 2,7V, 4Mbit | SO08 | SST 25VF040B | 0,97 | SST25VF040B-50-4I-SAF-N | 0,82 |
