projekte:ovi40-sdr:bom
UI-Platine:
BOM OVI40-SDR UI V1.724-09-2017DF8OEDistributor
IC1 /IC12WM8731Audio CODEC WM8731SSOP282238-WM8731SEDS/VWM8731SEDS/RVCT-ND3,63
IC2LM4952TSTI Stereo Audio PALM49521100-80283,72926-LM4952TS/NOPBLM4952TS/NOPB-ND3,06
IC3LP5907_Q1TI low noise LDO 3,3 VoltSOT23-51249-23040,654595-LP5907QMFX-3.3Q1296-38557-1-ND0,47
IC4STM32F76X_ZIT6MCULQFP1441253-549912,84511-STM32F767ZIT6497-16521-ND13,26
IC5ASTX-H1116 MHz TCXO 2,5ppm 3,2 x 2,5 mmTCXO_32X251815-ASTXH1116T535-12044-1-ND2,84
IC6KA78RM33R3,3 Volt LDODPAK1245-10410,681TS 2940 CP33821-TS2940CP33
IC7AT24CM02I2C EEPROMSO08124LC1026_ISN579-24LC1026I/SNAT24CM02-SSHM-B-ND1,89
IC8NCP5501DT50G5,0 Volt LDODPAK1170-33690,602TS 2940 CP50821-TS2940CP50
Q132,768 kHzQCM-315_SMDCM3151695-CM315D-32.7KEZFT300-8813-1-ND0,6
D6BAV70Double DiodeSOT23.
D7BAS85Schottky barrier diode SOD80C3146-93940,23BAS 85 SMD0,034771-BAS85135
D1greenLEDLED_3MM1276-49760,409LED 3MM ST GN
D2redLEDLED_3MM1276-49770,361LED 3MM ST RT
D3blueLEDLED_3MM1276-49750,443LED 3MM ST BL
BAT1-HOLDERBattery Holder CR20321188-59032,98BU2032-1-ND0,66
BAT1CR2032P_LLithium Battery 3,0VoltCR_2032_H1CR 2032P-H
L147uHL_SMD1005L10053221-56550,13MLZ2012M470WT0000,12
L247uHL_SMD1005L1005.
L347uHL_SMD1005L1005.
R147kSMD Resistor TK5008056SMD-0805 47k0,02
R1A100RSMD Resistor TK50060313SMD-0603 1000,03
R1B0RSMD Resistor TK5006033SMD-0603 00,03
R21kSMD Resistor TK5006037SMD-0603 1,0k0,03
R3100RSMD Resistor TK500603.
R41kSMD Resistor TK500603.
R4B12R2SMD Resistor TK5012064SMD ¼W 2,20,03
R4D2R2SMD Resistor TK501206.
R50RSMD Resistor TK500603.
R61kSMD Resistor TK500603.
R71kSMD Resistor TK500603.
R8100RSMD Resistor TK500603.
R94k7SMD Resistor TK5008054SMD-0805 4,7k0,02
R104k7SMD Resistor TK5006031SMD-0603 4,7k0,02
R114k7SMD Resistor TK500805.
R124k7SMD Resistor TK500805.
R1347RSMD Resistor TK5006037SMD-0603 470,03
R1447RSMD Resistor TK500603.
R151kSMD Resistor TK500603.
R16100RSMD Resistor TK500603.
R17100RSMD Resistor TK500603.
R18100RSMD Resistor TK500603.
R19100RSMD Resistor TK500603.
R20100RSMD Resistor TK500603.
R2147RSMD Resistor TK500603.
R2247RSMD Resistor TK500603.
R230RSMD Resistor TK5008058SMD-0805 00,02
R24680RSMD Resistor TK5008054SMD-0805 6800,02
R254k7SMD Resistor TK500805.
R26100RSMD Resistor TK500603.
R27100RSMD Resistor TK500603.
R28100RSMD Resistor TK500603.
R291kSMD Resistor TK500603.
R300RSMD Resistor TK500805.
R310RSMD Resistor TK500805.
R320RSMD Resistor TK500805.
R33100RSMD Resistor TK500603.
R34100RSMD Resistor TK500603.
R35A4R7SMD Resistor TK5012061SMD ¼W 4,70,03
R36680RSMD Resistor TK500805.
R37680RSMD Resistor TK500805.
R401kSMD Resistor TK500603.
R4147RSMD Resistor TK500603.
R452R2SMD Resistor TK501206.
R462R2SMD Resistor TK501206.
R4747RSMD Resistor TK500603.
R4847RSMD Resistor TK500603.
R1010RSMD Resistor TK500603.
R1080RSMD Resistor TK500805.
R1100RSMD Resistor TK500805.
R1120RSMD Resistor TK500805.
R1140RSMD Resistor TK500805.
R12047kSMD Resistor TK500805.
R12147kSMD Resistor TK500805.
R12247kSMD Resistor TK500805.
R12347kSMD Resistor TK500805.
R12447kSMD Resistor TK500805.
C11nFSMD Chip Capacitor NP0/COG060310KEM C0G0603 1,0N0,01
C5220uFSMD Tantal-ELKO 10VTA-C5TAJ 6032 220/100,46
C7470nFSMD Chip Capacitor NP0/COG06034NPO 0603 CD 470N0,04
C9220uFSMD Alu-Elko 16V low ESRE_SMD_06086VF 220/16 P-D80,3
C10100nFSMD Chip Capacitor X7R060363X7R 0603FCF 100N0,04
C1210uFSMD Tantal-ELKO 16VTA-B 3,5 x 2,89T494B 10U 16 0,51
C181uFSMD Chip Capacitor NP0/COG06038NPO 0603 CE 1,0U0,04
C244.7uFSMD Tantal-ELKO TA-A 3,2 x 1,61T491A 4,7U 160,04
C27220pFSMD Chip Capacitor NP0/COG08052NPO 0805 BG 220P0,04
C361nFSMD Chip Capacitor NP0/COG080510NPO G0805 1,0N0,04
C811uF SMD Chip Capacitor NP0/COG0603.
C831uF SMD Chip Capacitor NP0/COG0603.
C912,2uFSMD Chip Capacitor NP0/COG06032NPO 0603 CC 2,2U0,04
C93100nFSMD Chip Capacitor X7R0603.
C1071uF SMD Chip Capacitor NP0/COG0603.
C109220pFSMD Chip Capacitor NP0/COG06031NPO 0603AAF 220P 0,04
C1248,2pF – 10pFSMD Chip Capacitor06032NPO-G0603 10P 0,04
S1G3SMD Pushbutton KSC941J18243-51570,64CKN10433CT-ND0,55
S2G2SMD Pushbutton KSC941J.
S3M2SMD Pushbutton KSC941J.
S4BMSMD Pushbutton KSC941J.
S5G4SMD Pushbutton KSC941J.
S6M3SMD Pushbutton KSC941J.
S7SMSMD Pushbutton KSC941J.
S8SPSMD Pushbutton KSC941J.
S9M1SMD Pushbutton KSC941J.
S10F3SMD Pushbutton KSC941J.
S11F1SMD Pushbutton KSC941J.
S12F2SMD Pushbutton KSC941J.
S13F4SMD Pushbutton KSC941J.
S14BPSMD Pushbutton KSC941J.
S15F5SMD Pushbutton KSC941J.
S16G1SMD Pushbutton KSC941J.
S17PowerSMD Pushbutton KSC941J.
S18not assigned yetSMD Pushbutton KSC941J.
J11503_07Audio Plug 3,5mm1503_073121-70162,26LUM 1503-070,59
Button CapCap greyBTNKSC9204CKN10429-ND0,27
Button CapCap redBTNKSC9402CKN10428-ND0,27
Button CapCap blackBTNKSC9902CKN10426-ND0,27
Button CapCap whiteBTNKSC98010CKN10427-ND0,27
JP130 Pin Board to BoardPinheader-1×301×3013x 40-polig
JP3 6 Pin Board to BoardPinheader-1×061×064
P1SW_12VPinheader-1×021×026
JP8DEBUGPinheader-1×061×06.
LCD1Pinheader-2×172×171
LCD/PCBHoleheader low profile 2×17BL 2X17G 2,541
BU2MOLEX_SD_49225-0821MICROSD_CardreaderMolex 503182-18531176-43751,99HR1942CT-ND2,05
optional parts
IC9CY15B104QSPI FRAMSO08
IC11SST25VF04BSPI FLASH 2,7V, 4MbitSO08SST 25VF040B0,97SST25VF040B-50-4I-SAF-N0,82
  • projekte/ovi40-sdr/bom.1506535246.txt.gz
  • Zuletzt geändert: 27.09.2017 18:00
  • von df8oe
