Show pagesource Old revisions Backlinks Rename Page Export to PDF If a language is selected at the box above this line you will see page translation via google translate Do not use google translate if there is a native translation existent of the page - try a look at the little flag at the right top of every page!. Table of Contents OVI40 Wiki - Quick Guide Multi-language Wiki Automatic Translation General Information on the Wiki Discussion english publish OVI40 Wiki - Quick Guide Multi-language Wiki The OVI40 is set up as multi-language Wiki. Each language have their separate namespace. To summarise: Check first if the page / topic that interests you exists in your language (explanation below) If not: use Wiki automatic translation It may be interesting - even if the page exists in your language - to check the same page in other languages since the content may differ and contain additional information. Use automatic translation if needed. You may select your language here: Multi-language selection in OVI40 Wiki While reading a Wiki page you may also use this menu to select the same Wiki page in a different language. If the page exists in another language the language will be in black text. If it does not exist it will be gray. By clicking on a greyed language you may create this page. You are invited to create pages in your language. Any language missing in the multi-language menu will be added by simple request. Automatic Translation Certain pages may only exist in certain languages. The Wiki pages in certain languages may contain more informations than in other languages. For your convenience the OVI40 provides also automatic translation of Wiki pages: Automatic Translation General Information on the Wiki welcome https://www.dokuwiki.org/en:manual https://www.dokuwiki.org/wiki:syntax https://www.dokuwiki.org/plugin:bootnote You could leave a comment if you were logged in.
