UHSDR Bootloader General Reading
Forum:
Github Wiki:
Bootloader Installation - General Comments
- Option 1: Debug adapter approach. Preconditions:
- STM “ST-Link V2” adapter, STM Link SW
 - Option 2: STM “Defuse” approach. Preconditions:
- PC with STM Defuse Tool installed
 - USB to micro-USB cable (to connect PC with OVI40 mini-USB socket)
 - Option 3: USB-Stick approach. Preconditions:
- USB stick with correct boot loader image
 - prior boot loader installation existing and working on OVI40 UI
- *.bin file (pure binary file)
 - *.dfu file (containing binary and additional info such as target address on MCU)
"P6 Jumper" Method for very first boot loader upgrade
Close P6 jumper in case:
- There was never a UHSDR boot loader on the MCU (e.g. new assembled board)
 - Boot loader malfunctions, no upgrade with Defuse or USB-Stick possible
Option 1: ST-Link upgrade
ToDo
Preconditions
Procedure
Further Reading
Option 2: DeFuse Tool upgrade
ToDo
Preconditions
Procedure
- Boot loader installation described here
Further reading
ToDo
Preconditions
 - OVI40 UI powered up with 5V and 8V (JP1). The 8V powers the USB stick via voltage regulator
Procedure
Further reading
Note: ToDo
Bootloader laden
UHSDR Firmware laden
 - Drücke und (wichtig!) halte Taste “BAND -”
 - Taste “Band -” loslassen
