- Java from here https://www.java.com/en/download/win10.jsp
- If you run 64 bit windows make sure to install 64 bit JRE from here https://java.com/en/download/manual.jsp
- Install and test
- Gnu Arm toolchain from here, Win32 exe https://developer.arm.com/open-source/gnu-toolchain/gnu-rm/downloads
- Execute. Installs in C:\Program Files (x86)\GNU Tools ARM Embedded\7 2017-q4-major
- Download Gnu Arm Windows build tools from here https://github.com/gnu-mcu-eclipse/windows-build-tools/releases
- Copy all .exe files from “bin” directory from downloaded .zip to C:\Program Files (x86)\GNU Tools ARM Embedded\7 2017-q4-major\bin
- Install OpenOCD as explained here https://gnu-mcu-eclipse.github.io/blog/2018/01/23/openocd-v0-10-0-7-20180123-released/
- Install node.js “TLS” from here https://nodejs.org/en/
npm install xpm --global
- Install Quemu as explained here https://gnu-mcu-eclipse.github.io/qemu/install/
- Download latest Windows exe from here https://github.com/gnu-mcu-eclipse/qemu/releases
- Get latest MCU Eclipse from here https://github.com/gnu-mcu-eclipse/org.eclipse.epp.packages/releases/
- Extract downloaded zip file to c:\ (otherwise path names may become too long)
- Run GNU MCU Eclipse
- Follow work space preferences “global tool chain path” in https://gnu-mcu-eclipse.github.io/eclipse/workspace/preferences/
Install PAckages CMSIS
- In Eclipse Help→Install new software, Work with: “GNU MCU Eclipse plug-ins”, Click “What is already installed”
- Check that “GNU MCU C/C++ Packs (Experimental)” are installed, or install them
- When finished, in left window, choose STMMicroelectronics
- Install STM32F7 pack
- Ín left window, click once on STM32F7 series.
ToDo next: Git integration
