en:uhsdr_dev:win10_toolchain
npm install xpm --global
Install PAckages CMSIS
      • Install STM32F7 pack
    • Set/check that active project is correct
    • Set/check that device is correct:
      • For OVI40 with F7 MCU: Project → Properties → C/C++ Build → Settings → Devices → STM32F767ZI
      • For OVI40 with H7 MCU: Project → Properties → C/C++ Build → Settings → Devices → STM32H743ZI
  • in Eclipse Help→check for updates
Option: Github Desktop
  • Download Github desktop from https://desktop.github.com/
  • Start Github Desktop, enter your Githu username and password, clone repository “https://github.com/df8oe/UHSDR
  • Optional: create local branch of cloned repo for tests
  • In Eclipse, create new workspace pointing to local clone of cloned Github UHSDR repository
  • Check Eclipse settings for
    • active build config
    • MCU device used * …
Option: git commandline
Import git UHSDR project into Eclipse installation
  • The project is now recognized and can be imported * Next: check Eclipse settings
  • en/uhsdr_dev/win10_toolchain.txt
  • Last modified: 13.03.2018 09:34
  • by df9ts_user
