Segger J-Link Introduction
Segger provides a probe - J-Link - that can be used for programming and debugging. For non-commercial use Segger offers the low priced J-Link Edu probe.
For Debug output Segger offers an two options in MCU eclipse:
- Segger Real Time Tracing (RTT) with outputs debug messages in high speed via SWV debug lines (CLK and SWData). No need for an additional line to printout debug messages (as is the case with TRACESWO).
The J-Link makes use of the Cortex-M feature, which allows accessing the memory via the debug interface while the target is running. How this works in general is described here.
Install J-Link Software
Debian SW Install
Windows SW Install
ToDo
Segger J-Link adapter Firmware update
See here
Install Packs
J-Link and Eclipse
Segger Real Time Terminal RTT
- See here
RTT target code
Further reading:
- ToDo: Verify and try out
Flashing MCU with Segger J-Link
