Install J-Link Software
Debian SW Install
Windows SW Install
ToDo
Segger J-Link adapter Firmware update
See here
Install Packs
J-Link and Eclipse
Segger Real Time Terminal RTT
- See here
RTT target code
Further reading:
- ToDo: Verify and try out
ToDo
