Install J-Link Software
Debian SW Install
Windows SW Install
ToDo
See here
Install Packs
J-Link and Eclipse
Segger Real Time Terminal RTT
- See here
- See segger developper's site, search for RTT files: https://os.mbed.com/search/?q=SEGGER_RTT.c
- This leads to most recent .c and .h files for RTT: https://os.mbed.com/teams/anyThing-Connected/code/SEGGER_RTT/
- ToDo: Verify and try out
ToDo
Further Reading
