Install J-Link Software
Debian SW Install
Windows SW Install
ToDo
Install J-Link in GNU MCU Eclipse
See here
Install Packs
J-Link and Eclipse
Segger Real Time Terminal RTT
- See here
- ToDo: Verify and try out
ToDo
Further Reading
