en:ovi40what:specs
  • UI Board
  • Display und Touchscreen Module
  • RF Board
  • Housing
UI board table of features:
PCB Dimensions: 186mm x 66mm
Processor: STM32F76x (216 MHz Clock),
optional STM32H743ZIT6 (400 MHz Clock, pin compatible with STM32F76x)
Audio Codec: 2 x WM8731 @ 96KHz (UHSDR currently using 48 kHz only), separate IQ and Audio
(TX and RX possible simultaneously, RF board needs to support this)
Display: 3.5“ 480×320 as default, 3.2” and 2.8“ supported
LCD Interface: parallel and SPI supported, parallel used as default
Internal memory: SPI-Flash (Option), SPI-RAM (Option)
External memory: microSD card
Realtime clock: integrated Realtime Clock (RTC) part of STM32 MCU, CR2032 Backup Battery
LEDs: 3
External connections: Mini-USB Type B, USB-Host (USB-A),
3.5mm connector for microphone and PTT, 3.5mm connector for analog input,
3.5mm connector for analog output (line-out is independant from loudspeaker), 3.5mm connector for headset
Internal connections: 30pin connector (mcHF RF Board compatible), 6pin GPIO, 25pin connector (GPIOs, SPI, I2C), ST-Link V2 compatible Debug connector, Debug output, 2 x 4 Pin internal USB connections
Keys: 18 separate keys
Rotary encoders: 4 rotary encoders with integrated key function
Audio output: Stereo, 2 x 3W at 2 x 4 Ohm with less than 1% THD+N
Note: ToDo Photo
Display size: 3.5 inch
Display Type TN
Resolution: 480 x 320
Controller: ILI9846 (and compatible)
Human Interface: Touchscreen
Interface: SPI and Parallel
  • en/ovi40what/specs.1516479507.txt.gz
  • Last modified: 20.01.2018 20:18
  • by df9ts_user
