- Install on Win10 PC with Virtualbox
- ARM toolchain for Linux
- GDB
- Eclipse
GNU ARM toolchain for Linux
Note: Important: use latest version of tool chain from web sites below. DO NOT use the ARM toolchain that comes with your Linux distribution
- Download the latest Linux install tarball file from ARMDeveloper
$ mkdir -p ${HOME}/opt $ cd ${HOME}/opt $ tar xjf ~/Downloads/gcc-arm-none-eabi-7-2017-q4-major-linux.tar.bz2 $ chmod -R -w /home/gerd/opt/gcc-arm-none-eabi-7-2017-q4-major/
$ /home/gerd/opt/gcc-arm-none-eabi-7-2017-q4-major/bin/arm-none-eabi-gcc-7.2.1 --version
- Output should be like this:
arm-none-eabi-gcc-7.2.1 (GNU Tools for Arm Embedded Processors 7-2017-q4-major) 7.2.1 20170904 (release) [ARM/embedded-7-branch revision 255204] Copyright (C) 2017 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
GDB - GNU Debugger & OpenOCD
Check that GDB is installed in your Linux distribution by entering
$ gdb
The output should look like this:
GNU gdb (Debian 7.12-6+b1) 7.12.0.20161007-git Copyright (C) 2016 Free Software Foundation, Inc. License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html> [...]
If missing install with
apt-get install gdb
Install OpenOCD
- Test installation:
GNU MCU Eclipse and CDT
- Install Eclipse and CDT
Make the GNU Arm toolchain location known to Eclipse in Project→Properties→C/C++ Build→Environment→PATH. add the path to GCC here (in this example we would add /home/gerd/opt/gcc-arm-none-eabi-7-2017-q4-major/bin ).
