- Install on Win10 PC with Virtualbox
- ARM toolchain for Linux
- GDB
- Eclipse
GNU ARM toolchain for Linux
Note: Important: use latest version of tool chain from web sites below. DO NOT use the ARM toolchain that comes with your Linux distribution
- Download the latest Linux install tarball file from ARMDeveloper
$ mkdir -p ${HOME}/opt $ cd ${HOME}/opt $ tar xjf ~/Downloads/gcc-arm-none-eabi-6-2017-q2-update-linux.tar.bz2 $ chmod -R -w /home/gerd/opt/gcc-arm-none-eabi-6-2017-q2-update/
$ /home/gerd/opt/gcc-arm-none-eabi-6-2017-q2-update//bin/arm-none-eabi-gcc-6.3.1 --version
- Output should be like this:
arm-none-eabi-gcc-6.3.1 (GNU Tools for ARM Embedded Processors 6-2017-q2-update) 6.3.1 20170620 (release) [ARM/embedded-6-branch revision 249437] Copyright (C) 2016 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
GDB - GNU Debugger & OpenOCD
Install OpenOCD
- Test installation:
GNU MCU Eclipse and CDT
- Install Eclipse and CDT
Next step: import UHSDR into gnu arm eclipse
