Pull UHSD source code from Github
Option: Download the zippd UHSDR
- The easiest approach is to donload the zipped UHSDR source code from Github UHSDR repository and unpack.
- If using Eclipse: create a work space pointing at the local directory where UHSDR has been unpacked. Check Eclipse settings after that (active build etc.)
Option: Use "Github Desktop"
- Download Github Desktop. The .exe file is the executable (portable) program and does not need installation
- Provide your github username and password, clone the Github UHSDR repository
- Optional: Create a local branch for your source code changes
Option: Use "git" on command line level, Unix style
Pull UHSDR from Github
- If git is not intalled on your system:
$apt-get install git
- Clone UHSDR repository: <code>$git clone https://github.com/df8oe/UHSDR.git
Option: Create work space
- Start Eclipse. File→Switch workspace→Other
- Enter directory of local UHSDR clone.
- When using this new work space Eclipse will use settings of UHSDR clone. So please check Eclipse settings (active build, ..)
- File→Import, then General→Existing Projects into work space, hit “Next”
- “Select root directory”. Use “browse” button and point to local github mchf root (in my case: $HOME/uhdsrd/UHSDR/mchf-eclipse/)
- Hit “Finish”
