OVI40 Specifications
UI board, table of features:
PCB form factor: | 186mm x 66mm |
processor: | STM32F76x, optional STM32H743 (144pin LQFP) |
audio codec: | 2 x WM8731 @ 96KHz (actually firmware supports 48KHz), IQ and audio seperated, (simultaneously TX and RX possible, if RF board supports it) |
display: | 3.5“ 480×320, supporting more LCDs later |
LCD interface: | parallel / SPI |
internal memory: | SPI-Flash (optional), SPI-RAM (optional) |
external memory: | microSD Card |
real time clock: | integrated RTC of STM32, CR2032 backup battery |
LEDs: | 3 |
external connectors: | Mini-USB Type B, USB-Host (USB-A), 3.5mm microphone and PTT, 3.5mm Stereo analog in, 3.5mm Stereo analog out (speaker independent), 3.5mm Stereo audio uut (headphones) |
internal connectors: | 30pin pinheader (mcHF compatible) +6pin GPIO, 25pin pinheader (div. GPIOs, SPI, I2C), STLinkV2 compatible connector, debug print, 2 x 4pin internal USB connectors |
buttons: | 18 independent |
encoders: | 4, with independent push functions |
audio output stage: | stereo, 2x3W |
30pin header J1 is downcompatible to mcHF rf PCB so that you can use OVI40-UI in bundle with mcHF rf (version ⇐ 0.6). Of course only features which are supported by this rf PCB will be available.
