Installation du programme d'amorçage ("boot loader") - Commentaires généraux
Trois options différentes existent pour effectuer l'installation ou la mise à niveau du “boot loader”:
* Option 1: l'adaptateur de débogage. Ceci nécessite: * Adaptateur STM “ST-Link V2”, STM Link SW * Option 2: Approche STM “Defuse”. Ceci nécessite: * PC avec STM Defuse Tool installé * Câble USB vers micro-USB (pour connecter un PC avec une prise mini-USB OVI40) * Option 3: Approche clé USB. Ceci nécessite: * Clé USB avec fichier de “boot loader” copié là-desus * installation préalable du chargeur de démarrage “boot loader” existant et en état de marche
- *.bin file (pure binary file)
- *.dfu file (containing binary and additional info such as target address on MCU)
"P6 Jumper" Method for very first boot loader upgrade
Close P6 jumper in case:
- There was never a UHSDR boot loader on the MCU (e.g. new assembled board)
- Boot loader malfunctions, no upgrade with Defuse or USB-Stick possible
Option 1: ST-Link upgrade
ToDo
Preconditions
Procedure
Further Reading
Option 2: DeFuse Tool upgrade
ToDo
Preconditions
Procedure
- Boot loader installation described here
Further reading
ToDo
Preconditions
- OVI40 UI powered up with 5V (Pin 28 JP1) and 8V (Pin 29 JP1) and GND (Pin 30 JP1). The 8V powers the USB stick via voltage regulator
Procedure
- Supply +8V on JP1 pin 29 - to pwer USB stick
- Push and - important - hold switch “BAND -”
- Supply +5V on JP1 pin 28 - this starts the boot loader
- insert USB stick into large USB port of OVI40 UI
- Wait for FW upload to finish
- Release switch “Band -”
- Remove +5V, then apply again to reboot OVI40 UI.
Check proper working of newly loaded boot loader
UHSDR Bootloader further reading
Forum:
Github Wiki:
