11. October 2026, 18:20:11
Diskussions- und Newsboard des DARC-Ortsverbandes I40  |  allgemeine Kategorie  |  OVI40 SDR Projekt (English AND German discussions around OVI40 SDR project) (Moderators: DF8OE, DL1PQ)  |  Topic: LCD 3.5" DF8OE/SP9BSL <- zurück vorwärts ->
Pages: 1 [2] 3 4 Go Down Print
   Author  Topic: LCD 3.5" DF8OE/SP9BSL  (Read 21278 times)
Re:LCD 3.5" DF8OE/SP9BSL
« Reply #15 on: 10. January 2018, 18:35:48 »
Yes, that must be.
Please give every possible feedback you can give. I will collect all errors in parts and sizes and amounts.
100nF capacitor is a "spare" one. I added it to every order.
« Reply #16 on: 11. January 2018, 16:22:22 »
Thomas, could you please measure the voltage on 4R7 resistor? I'm just curious how much current the backlight draws.
« Reply #17 on: 11. January 2018, 16:56:26 »
Thank you! 80mA is quite much, but if you do not have lcd hot, it is ok.
« Reply #18 on: 11. January 2018, 17:36:18 »
I have take a look at the datasheet. It tells 60mA is maximum for time > 1 min. for time < 1 min 75mA is the highest rate.
I am quite happy with my fitted 15R - LCD is brighter than mcHF with 3.2" LCD which is standing directly near my OVI40.
df9ts
« Reply #19 on: 14. January 2018, 23:20:56 »
Ich habe eine Display Platine, bei der noch die Leitung durchtrennt werden muss.
Könnte mir jemand ein kleines Photo der entsprechenden Stelle machen? Vielen Dank
Gerd.
LCD 3.5" DF8OE/SP9BSL cutting of LCD serial SDO
« Reply #20 on: 15. January 2018, 06:23:02 »
Cut the track which is shown in the following picture. It is the "data output" line of LCD which isn't in tristate mode even when LCD is driven in parallel mode. If track is not cut touchscreen controllers ADS8743 or TSC2046 are not recognized!
I have already modified all LCD PCBs which are shipped after 01/04/2018.
« Last Edit: 15. January 2018, 06:24:11 by DF8OE »
OE3HKC
« Reply #21 on: 16. January 2018, 13:51:39 »
Hallo Andreas, eine Frage:
darf ich annehmen, dass es nicht stört, wenn so -wie auf meinem UHSDR-OVI40-LCD-Board- auch die Leitung "TP SDI" zu Anschluss 13 der 40-poligen Buchse J106 durchgekratzt ist ?
ohne TP SDO-Signal macht ja ein TP SDI-Signal auch keinen Sinn  könnte ich mir vorstellen...
vy 73,
Helmut
« Reply #22 on: 16. January 2018, 14:08:04 »
I can confirm, of course it does not matter, we do not use lcd SPI for OVI40 UI board
« Last Edit: 16. January 2018, 14:08:26 by SP9BSL » Logged
OE3HKC
« Reply #23 on: 16. January 2018, 14:11:26 »
Danke Thomas, hab nämlich gerade die 40-polige Leiste bestückt und kontrolliere danach sofort auf Schlüsse oder Unterbrechungen... sicher ist sicher...
vy 73, Helmut
Danke auch Slawek
« Last Edit: 16. January 2018, 14:13:07 by OE3HKC » Logged
« Reply #24 on: 16. January 2018, 14:22:02 »
vielleicht noch eine andere Ergänzung:
ich habe nach Thomas' Hinweis den IC103 runter genommen und die Pins 3 und 4 mittels 0R (oder Drehbrücke) verbunden. Spielt als "Parallel-Display" problemlos.
« Reply #25 on: 16. January 2018, 15:47:50 »
Ausserdem ist nicht TP_SDO durchgekratzt, sondern LCD_SDO.
Und irgendawnn in der Zukunft wird auch der serielle Teil für den LCD ausprobiert. Aber "I strongly recommend parallel".
« Reply #26 on: 16. January 2018, 16:07:12 »
Thomas,
auf dem LCD-Panel ist gar kein TP-Controller. Dementsprechend kann auch am FPC kein TP_SDx liegen.
Und die Stiftleiste hat 34 Pole.
Wir müssen hier sehr genau schreiben, um uns nicht gegenseitig zu verwirren
Hier der Auszug aus dem Original-Datenblatt des LCD-Panels
« Last Edit: 16. January 2018, 16:15:40 by DF8OE » Logged
OE3HKC
« Reply #27 on: 16. January 2018, 20:35:58 »
manchmal passiert es eben, dass "alte oder ungültige Netznamen" bei Änderungen erhalten bleiben...
ist mir damals im job auch manchmal passiert...
irgendjemand kommt drauf, entdeckt es und fragt nach...
alles kein Problem, wir sind ja immerhin "Amateure" und wie der Name schon sagt, lieben wir unser Hobby...
jeder gibt sein Bestes und erfreut sich am persönlichen Erfolg.. oder wenn er einem Gleichgesinnten helfen konnte...
ich für meine Person habe dieses "MaxiPIX-Display" für meinen kleinen "MiniTRIX" auserkoren und werde es als abgesetztes betreiben...
sobald es damit läuft, werde ich einen eigen Thread in der mcHF-Abteilung aufmachen...
vy 73, danke und noch einen angenehmen Bastelabend wünscht
Helmut
OE3HKC
« Reply #28 on: 16. January 2018, 20:47:21 »
und an Andreas...
danke auch für die Tabelle mit der Anschlussbelegung der 40-poligen Buchsenleiste...
jetzt ist mir vieles klarer, zumal der Kommentar in chinesischen Schriftzeichen darüber restlos Aufschluss gibt...
ich habe nebenberuflich vor ein paar Jahren eine 2-jährige Ausbildung in chinesischer Heilmassage (Tuina) an einem Wiener Massageinstitut absolviert... war eine gute Sache...
diesbezüglich haben die Chinesen eine Menge am Kasten... die alten jedenfalls
in diesem Sinne vy 73,
Helmut
« Last Edit: 16. January 2018, 21:01:35 by OE3HKC » Logged
« Reply #29 on: 17. January 2018, 07:06:13 »
Jetzt habt ihr sicher eine Ahnung davon was es für Verwirrungen gäbe, wenn ich mit halbfertigen RF-Teilen oder Schaltungen hier aufschlage. Nichts ist dokumentiert, vieles ist noch nicht endgültig: das kann nur dazu führen, dass keiner weiß, was los ist
Denn das LCD ist wirklich eine Mini-Baustelle. Die haben Slawek und ich in 4 oder 5 Mailwechseln erschlagen. Und bis auf die Sache mit dem SDO des LCD ist auch alles perfekt geworden. Und das SDO braucht im Moment sowieso niemand.
Pages: 1 [2] 3 4 Go Up Print
