15. July 2025, 21:05:03
Pages: 1 ... 18 19 [20] 21 22 ... 25 Go Down Print
   Author  Topic: letzte Betatestrunde ist gestartet  (Read 75566 times)
« Reply #285 on: 19. November 2017, 17:12:02 »
I can confirm that this problem doesn't occur on my mcHF. Yesterday all day long i had it on receive and changing to CW and SSB, but nothing happened. I have 3.5" lcd ofcourse and latest build.
« Reply #286 on: 19. November 2017, 17:24:29 »
Hi Slawek,
yes: it does not have reason in your code. It also occurs if I take active-devel source for building. And because of I intensively have tested new LCD feature I wasn't so interested in this issue. But now - I wait for merging - I am back again with testing such "standard functions". I am sure we will find and fix it.
« Reply #287 on: 19. November 2017, 23:20:54 »
Hallo Andreas
Bis jetzt ist sowas hier auch noch nie aufgetreten. Das Gerät lief schon mehrere Stunden am Stück, meistens 20 oder 40m in SSB.
Gruss Reto
Re:letzte Betatestrunde ist gestartet/FW2.7.1
« Reply #288 on: 20. November 2017, 06:57:07 »
die farbliche Unterscheidung der eingestellten Bandbreite im Scope-Betrieb finde ich Klasse.
Danke
« Reply #289 on: 20. November 2017, 08:24:19 »
Bedanke Dich bei Slawek SP9BSL
« Reply #290 on: 20. November 2017, 16:30:15 »
Hi Thomas,
you're welcome. I'm glad that you like it. It works better than my first one which i did in June. It was possible thanks to display code reworked by Danilo. Anyway I'm happy to be in this team!
Co
« Reply #291 on: 20. November 2017, 16:50:18 »
Re: Audio distortion
I had the set on all afternoon but could not detect any audio distortion.
After I connected the RF board to the OVI40 UI board the blue screen (button test)did not appear any more ! The reason might be that since power is now supplied by the RF board some delays are introduced by the power switching arrangement.
regards
Co
« Reply #292 on: 20. November 2017, 17:01:46 »
Hallo an alle,
danke für eure Rückmeldungen / thank you for your reports.
Ich habe in der Zwischenzeit herausgefunden, dass das USB-Audio unverzerrt bleibt, wenn das Audiocodec-Audio verzerrt ist. Die Platine ist nicht biegeempfindlich, die Verzerrungen kommen und gehen in laufzeitunabhängigen Intervallen und ich kann sie mit Wärme/Kälte weder hervorrufen noch beseitigen. Nachlöten (MCU/U1) hat nichts verändert. Und es muss (wenn es an einem Codec liegt) U1 sein.
Sie müssen irgendwo zwischen dem STM und dem Lautsprecher entstehen, die RF Platine kann damit zum Glück nichts zu tun haben. Weiter bin ich noch nicht.
Auf jeden Fall erhärtet sich der Verdacht nach einem Hardwareproblem.
« Reply #293 on: 21. November 2017, 18:40:49 »
Ich verstehe nicht warum, aber der Audiocodec U1 war partiell defekt. Absolut seltsam und dabei habe ich dem Codec doch gar nichts getan...
Es war nur der D/A Wandler - aber beide. Ohne erkennbaren Anlass, bei stabiler Betriebsspannung und unabhängig von Betriebsdauer und Temperatureinflüssen hat er mal vernünftig gewandelt und ab und zu hörte es sich so an, als wenn ein paar Bit gefehlt haben (in jedem Wort). Das war das Letzte, was ich vermutet hatte deswegen habe ich ihn erst vorhin getauscht. Seitdem ist meine OVI40-UI auch absolut verzerrungsfrei.
« Reply #294 on: 21. November 2017, 19:15:05 »
i had similar issue a year ago with WM8569. Two of 10 mounted on SMD line failed after 1 night of work (warm test before packing and sending to customer). It was definitelly not an ESD... Both pieces was hot when failed (only DAC issue, ADC was working ok). Unfortuntelly manufactured by Wolfson not Cirrus Logic...
« Reply #295 on: 21. November 2017, 19:28:09 »
ich habe einen ESD-Arbeitsplatz - schließlich repariere ich täglich Notebooks. Und meine gesamten Abläufe habe ich so im Blut, dass mir auch keine ESD-Panne mehr passiert. Es ist einfach nicht zu klären.
Aber wie Du schon schriebst: "Entwarnung für die Zukunft". Das hat nichts mit der Schaltung selbst oder der Firmware zu tun.
« Reply #296 on: 22. November 2017, 11:40:19 »
Hallo zusammen ich habe da mal einen Frage werden mittlerweile schon die 3 Speicher ICS von der firmenware unterstützt da ich grade in den letzten Zügen bin das Bord fertig zu stellen denn Audio Verstärker kann ich ja direckt an die 12V Buchse hängen
« Reply #297 on: 22. November 2017, 11:57:08 »
@ANDY;
Nach meinem Kenntnisstand wird nur der IC7 (1025, 1026 oder wie bei mir AT24CM02) unterstützt.
Es erfolgt auch nur die Erkennung des IC7 in den Systeminfos
Die anderen beiden sind für die Zukunft
« Reply #298 on: 22. November 2017, 12:02:16 »
Hallo Andy,
Michael_K hat absolut recht: Derzeit gibt es keine aktuellen Pläne diese Speicher in der Firmware zu nutzen. Ob jemand in nächster Zeit mit einer Idee um die Ecke kommt, bei der so ein Speicher hilfreich ist, wissen wir natürlich nicht und dafür sind sie auch vorgesehen: für zukünftige Experimente/Funktionen (ohne zu wissen, welche das wann sind). Ist nur schwer, sowas nachträglich einzubauen, deswegen schon mal der Platz auf der Platine.
Co
« Reply #299 on: 22. November 2017, 15:56:18 »
On the OVI40 I replaced the LCD  screen because touchscreen leads are damaged. I installed another lcd. But when I press power to start, the splash screen comes up briefly immediately followed by the blue button test screen. I can test the buttons with normal feedback on the putton pressed and touch screen coordinates and by a long press on the band- the set performs a reboot but only to repeat the same sequence : splash screen  followed by button test. I can break the loop only by powering off with the power button.
When I go back to the old lcd all behaves normally. I can't follow the logic. Would appreciate some advice.
Kind regards
Co
Pages: 1 ... 18 19 [20] 21 22 ... 25 Go Up Print
