09. July 2025, 09:12:35
Pages: 1 ... 16 17 [18] 19 20 ... 25 Go Down Print
   Author  Topic: letzte Betatestrunde ist gestartet  (Read 75446 times)
S53DZ
« Reply #255 on: 15. November 2017, 07:14:33 »
Excellent job Slawek with 3.5", also the placement on the screen looks very likable to me.
73 Bojan
« Reply #256 on: 15. November 2017, 07:26:12 »
Thanks, we have the testing time now, and some of the items may change its positions by little.
« Reply #257 on: 15. November 2017, 08:42:54 »
Wow, that looks absolutely fantastic ! Software team has done a great job here. Congrats !
« Last Edit: 15. November 2017, 08:44:42 by peter_77 » Logged
« Reply #258 on: 15. November 2017, 09:24:08 »
Yes. Impressive work and impressive looking. I have already tested and it is working good. Of course there are some parts which are not finished yet, some which are not fully satisfying, but it is the first draw of this LCD layout and first integration and I like it.
As I already wrote this will be the "standard LCD" for OVI40. All betatesters can move their ui PCBs to this state by just swapping the LCD and flashing new bootloader and firmware. Detection of the LCDs will NOT be on runtime (at this state). And I do not see any advantages by doing that. OVI40 firmware will be released with this LCD so only one version of bl/fw will be needed.
Everyone who wants to take a look at the actual development can do this "life" at Afumesse Dortmund. I will have a prototype of RF board conneceted and will tell some technical specifications. PCB will NOT be shown (I hide it) and is not fully working at this stage but it contains the latest development states.
I hope that my LCD samples from CN will arrive the next 14 days so that I can start manufacturing of the LCD PCBs which, as I already wrote, will available at the same time ui-PCB will be available.
« Reply #259 on: 15. November 2017, 11:00:25 »
wichtig finde ich die Aussage von Andreas, daß das 3.5"-Display der Standart für den UHSDR OVi40 wird. Damit ist die Richtung klar.
Habe heut mal im WWW gesurft und eine Reihe Eigenbaugeräte und -Entwicklungen gefunden (speziell im cqham.ru), die verallgemeinerungswürdige Tendenzen der Displayansicht zeigen.
Das sind
a) eine "Aufgeräumtheit" der Anzeigen, d.h. wirklich die, die man im praktischen Betrieb braucht, und
b) die gleichzeitige Darstellung Spektrum und Wasserfall
« Reply #260 on: 15. November 2017, 11:42:51 »
Thomas,
we have some code already implemented for RA8875 (same as for Tulipan), so in the future there will be also an option...
« Reply #261 on: 15. November 2017, 11:44:05 »
Es ist halt so dass man mit 480x320 mehr darstellen kann als mit 320x240. Es ist im Prinzip eine Verdopplung der Punkte. Natürlich werden diese dann aber auch kleiner! Aber das LCD ist "schärfer" als das 3.2" 320x240. Unbestritten ist die größere Leistungsfähigkeit des neuen LCD Controllers und auch dass es mehr Möglichkeiten gibt. Diese werden Anfangs mit Sicherheit noch nicht voll ausgeschöpft werden und auch nicht perfekt sein. Aber wie Michael sagt: Es gibt auch da bereits andere Konzepte und dank GPLv3 kann man sich dann bei solchen Konzepten bedienen.
In der Firmware ist bereits jetzt sehr viel Communityarbeit von Leuten, die vielleicht noch nicht mal wissen, dass ihre Arbeit dort Einzug gehalten hat, weil nicht jeder das ganze Web verfolgt. Und wenn man sich erstmal davon gelöst hat, dass alles, was man macht und hat einem selbst gehören muss mit Lizenzstempel etc. sondern dass man sich einfach daran erfreuen kann, dass es toll funktioniert und dass man auch stolz darauf sein kann, die Puzzlesteine selbst zusammengesteckt zu haben (oder nur einige kleine selbst dazugepackt zu haben) dann ist das ein tolles Ergebnis für alle.
Ich denke dass wir zu gegebener Zeit noch über das Layout reden werden und Vorschläge machen (und annehmen).
@Slawek
I already have planned to release two housing concepts for OVI40. One small which is very good for portable use and one which is for stationary use. The one which is for stationary use can hold bigger LCDs and more resolution. But that is a point for the future. The door you need to go there is already present at OVI40.
« Last Edit: 15. November 2017, 11:46:44 by DF8OE » Logged
Co
« Reply #262 on: 15. November 2017, 13:56:17 »
Hello Andreas,
After loading the latest version of the bl and fw (with STLINK) the test-button screen does'nt appear anymore. Problem seems to be solved here.
Developers did a very nice job on the 3.5" lcd. Hope it will be available soon.  I did'nt like the butchering of the 3.2" lcd. Backlight distribution is somewhat disturbed now. Apparently I was not carefull enough!.
Regards
Co
« Reply #263 on: 15. November 2017, 14:09:51 »
Hi Co,
we have not done anything regarding button test.... New LCD will be available at official release of OVI40 UI - maybe earlier.
Co
« Reply #264 on: 15. November 2017, 14:21:46 »
Andreas,
IT did here. Upon connecting power to the stand alone UI board intermittently the the blue 'test button' screen appeared allowing booting by pressing band-.
That effect now disappeared.
regards
Co
« Reply #265 on: 15. November 2017, 15:14:46 »
That is "by chance". Nothing changed in that area.
« Reply #266 on: 15. November 2017, 15:57:44 »
Kannst Du mal den TP-IRQ komplett vom LCD abnehmen? Also "in der Luft hängen lassen"?
An die Sache müssen wir uns rantasten. Ich kann nicht, weil es bei mir nicht auftritt.
« Reply #267 on: 15. November 2017, 16:24:41 »
Ja. Einfacher Workaround.
Da ich zur Zeit die Binaries zweier Versionen parallel pflege (die normale active-devel und die für die neuen LCDs) möchte ich mit dem Einpflegen (das sehr einfach ist) noch warten bis wir die beiden Branches wieder verheiratet haben. Ich habe wirklich genug zu tun und möchte mir nicht noch zusätzliche Arbeit ans Bein binden. Es ist ja ein "minor-bug"
« Reply #268 on: 15. November 2017, 16:38:05 »
Die Kardinalsfrage ist ja wie diese Aussage jetzt genau zu verstehen ist. Hat man weiterhin die Möglichkeit auch das 3.2" (HV32D) von der Stange zu verwenden ODER das neue 3.5" Display oder wird letzteres Pflicht ohne weiteren "Standard Display" Support in welchem Format auch immer ?
Würde ja etwas Andreas' Philosophie von "Zwangs Bauteilen" widersprechen mit denen man am Fliegenfänger hängt.
Wobei natürlich die Frage eher hypothetischer Natur ist, denn bei annähernder Kostengleicheit würde es wenig Sinn machen ein schlechteres Display mit weniger Features zu verwenden sofern die Verfügbarkeit auch bei Ausfall gesichert ist.
Macht es deshalb nicht dennoch Sinn auch die Option eines Standard Displays, egal ob 3.2" oder auch 5" weiterhin im Köcher zu haben ? Just in case...
« Last Edit: 15. November 2017, 16:47:14 by peter_77 » Logged
« Reply #269 on: 15. November 2017, 17:10:56 »
Der OVI40 wird definitiv mehrere Displays unterstützen. Das fängt beim ili932x (320x240) an, geht über das jetzt defaultmässige 3.5 ili9486 mit 480x320 und wird später auch 5 oder noch größere LCDs mit dem RA8875 Controller (640x480 oder 800x600) unterstützen.
Allerdings muss für jede dieser Versionen mit einem #define (oder mit dem Makefile bequem über eine Umgebungsvariable) eine eigene Firmware-Version gebaut werden, weil es aus verschiedenen Gründen vorerst keine Autodetect dafür geben wird. Die default-Firmware wird eben für das 480x320 gebaut sein.
Ich überlege aber auch, auf meinem Webserver eine Entwicklungsumgebun einzurichten und für das Maefile ein php-Interface. Dann kann man per Radiobutton "seine" Version wählen und bauen lassen - auch von älteren Versionen. Dann könnte man das noch so machen, dass man von der aktuellen Version die gebauten Binaries cached so dass nicht bei jedem Aufruf neu gebaut werden muss, und bei den älteren werden Binaries gelöscht, auf die länger als z.B. zwei Wochen nicht mehr zugegriffen wurde.
Nichts ist unmöglich...
Und "Zwang" ist das nicht wirklich. Ich gehe davon aus, dass es, wenn sich das rumspricht, von diesem LCD auch bald andere Anbieter geben wird.
Pages: 1 ... 16 17 [18] 19 20 ... 25 Go Up Print
