18. October 2026, 02:47:58
Diskussions- und Newsboard des DARC-Ortsverbandes I40  |  allgemeine Kategorie  |  OVI40 SDR Projekt (English AND German discussions around OVI40 SDR project) (Moderators: DF8OE, DL1PQ)  |  Topic: Starting FPGA understanding and experimentals <- zurück vorwärts ->
   Author  Topic: Starting FPGA understanding and experimentals  (Read 4174 times)
« on: 16. April 2020, 12:42:20 »
ISE installation tutorial is out in the wilderness and I suggested to start with an unexpensive development board called Mojo V3
I will supply some more informations and hints how to start using Spartan XC6SLX9 now.
Of course there are technical documentations available for Mojo:
There is an IDE for working with Mojo similar to Arduino IDE (what surprise: Mojo was released by Adafruit). Installing this IDE on Arch Linux is quite easy:
Code:
yay -S mojo-ide
This will end in an error because the url for downloading has changed. Now simply modify the download url which is located in PKGBUILD (you can find PKGBUILD for mojo-ide in ~/.cache/yay/mojo-ide/ ) following information from AUR database. Now finish the installation like that:
Code:
cd ~/.cache/yay/mojo-ide
makepkg
sudo pacman -U mojo-ide-B1.3.6-1-x86_64.pkg.tar
Now Mojo IDE is ready for start. You need to configure the path to Xilinx ISE binary and (if connected) the serial port for Mojo board (which is usually /dev/ttyACM0).
Now you need some inspiration
Have fun!
« Last Edit: 16. April 2020, 13:53:55 by DF8OE » Logged
