Topic: Aufbaubericht OVI40-UI Platine Version 1.8 (Read 31759 times)
sm0nor
Re:Aufbaubericht OVI40-UI Platine Version 1.8
« Reply #120 on: 04. February 2018, 12:55:51 »
Hi all! First time SMD soldering :-). Works fine (of course I have done normal soldering for 40 years). I'm about 20% done, so a long way to go still . I'm still trying to figure out the best soldering tip to use. I have half a dozen of tips to my 1970's Weller Magnastat. P06, P07, P08 in various shapes and sizes. It seem the "bigger" ones, ca 1,2mm, are easier to work with than the smaller ones. But I'm still applying to much solder in my opinion..
What are your favourite tips? Temperature?
73's Ulf SM0NOR
« Last Edit: 04. February 2018, 12:57:00 by sm0nor » |
« Reply #121 on: 04. February 2018, 13:27:25 »
Hi Ulf, I also use a Weller here, but something more modern. 1.2mm soldering tip is ok. Temperature 400 degrees Celsius... Maybe it's a bit much, but I'm fine with it.
I wish you success!
db9mat
« Reply #122 on: 04. February 2018, 18:16:11 »
400°C is _way_ too much, especially for leaded solder.. 340 is more than enough
« Reply #123 on: 04. February 2018, 18:50:10 »
Ich wusste dass sowas kommt Davon ab löte ich seit geraumer Zeit bleifrei, aber auch früher hab ich schon immer mit 400*C und mehr gelötet.
Mir ist auch noch nie etwas kaputt gegangen noch gab es irgendwelche Reklamationen die auf meine Löttemperatur zurückzuführen wäre
sm0nor
« Reply #124 on: 09. February 2018, 21:33:58 »
Hi All! Everything goes well here. A bit slow, but I'm in no rush. I just wonder how I solder the TXCO IC5? Will the solder flow in under the IC and make connection? I mean it is hard to see if it has connected since the pads are under it. Tried to google a bit but didn't find anything useful. Is there a way to check if it has made connection? 73's Ulf SM0NOR
sm0nor
« Reply #125 on: 10. February 2018, 07:56:24 »
Got it! I found the answer myself by reading the thread about hot air station. I will purchase el cheapo this week. 73's Ulf SM0NOR
positron alter Hase
« Reply #126 on: 10. February 2018, 08:40:27 »
This is good, have to add it to my best sentences list Good decision anyway.
df9ts
positron schon länger dabei
« Reply #127 on: 10. February 2018, 09:52:12 »
TXCO can be solder with normal tip.
Tin-coating the TXCO pins and PCB pads helps, remove most of it with solder wick, then apply flux. Solder TXCO in by heating up the PCB pads, heat will go under the TXCO. Worked on two UI boards.
El cheapo..
Anyway hot air is nice to have.
Gerd.
DL4HAO_Dietmar
« Reply #129 on: 14. February 2018, 11:29:50 »
Hallo zusammen!
Da ich aktuell ein paar Tage Urlaub habe, kam die Zusendung des Bausatzes gerade richtig (Sammelbestellung von Jürgen, DD2XJ). Danke!
Ich bin nun bei Beutel 3 und finde dort einen 8-Beiner (ist wohl ein SO08 Gehäuse) mit dem Aufdruck (obere Reihe) ATMLH746 in der mittleren Reihe steht 2H M B und in der unteren Reihe steht .A7TK3A
Welches IC ist das denn? Ist das ein Ersatz für IC7 AT24CM02, ein I2C EEPROM?
In der Packliste für Beutel 3 finde ich nicht die Bezeichnung dieses Bauteils, auch nicht, dass das IC7 sein soll. In der gesamten Packliste finde ich die Bennenung der Bauteile nicht, also welches Bauteil denn in Beutel 3 nun Diode-X oder IC-Y oder Transistor-Z ist.
Ist mein ATMLH746 nun dieses IC7 AT24CM02?
In dem Errata habe ich für Beutel 3 keinen Eintrag gefunden.
vy73 Dietmar, DL4HAO
Große Geister unterhalten sich über Ideen, Durchschnittsmenschen über Ereignisse und kleine Leute über andere. (Sokrates)
DL4HAO_Dietmar
« Reply #131 on: 14. February 2018, 12:04:24 »
Danke, Gerd. Ich hatte gedacht, dass ich in der Auflistung der Beutel auf der von Dir im Link genannten Seite auch solche Hinweise finde, zu den Bauteilen, die sich im Beutel 3 befinden oder befinden sollten, aber da gibt es andere Beutel, nicht den Beutel 3. Nun bin ich schlauer, danke
DL4HAO_Dietmar
« Reply #132 on: 15. February 2018, 13:15:50 »
Hallo zusammen!
Es geht um die UI-1.8 Platine, da steht R1A oder R1B. Welcher steht wofür? Welcher soll wann eingelötet werden? Ich habe im Wiki und auch in diesem Forum mit dem Suchbegriff R1A und auch R1B keinen Treffer gelandet.
DL4HAO_Dietmar
« Reply #134 on: 15. February 2018, 13:33:06 »
Hallo ?, danke für Deine schnelle Antwort.
... hmmm, ja, das hatte ich schon gesehen, ich bin auf der Suche nach einer Antwort, wie ich mich entscheiden soll, wenn ich -was- damit machen möchte. Wann bestücke ich denn nun R1 (immer?) oder nur R1A oder nur R1B oder alle drei?
, Dietmar
