01. May 2024, 10:32:25
Diskussions- und Newsboard des DARC-Ortsverbandes I40  |  allgemeine Kategorie  |  OVI40 SDR Projekt (English AND German discussions around OVI40 SDR project) (Moderators: DF8OE, DL1PQ)  |  Topic: Baubericht: UI mit 480MHz STM32H743ZIT6U <- zurück vorwärts ->
Pages: 1 [2] Go Down Print
   Author  Topic: Baubericht: UI mit 480MHz STM32H743ZIT6U  (Read 15108 times)
Re:Baubericht: UI mit 480MHz STM32H743ZIT6U
« Reply #15 on: 12. January 2020, 18:11:38 »
Da der DAC in beiden Fällen identisch arbeitet kann es nicht am STM liegen.
« Reply #16 on: 02. September 2020, 15:30:00 »
Hi
Thomas, I can't upload the bootloader (https://www.amateurfunk-sulingen.de/uhsdr/bootloader-latest/OVI40/H7/) to the STM32H743ZIT6U.
I have an error like this:
What am I doing wrong?
Artur
« Reply #17 on: 02. September 2020, 16:29:58 »
Old program?
Thomas, what version of ST32-Link are you using?
« Reply #18 on: 02. September 2020, 16:41:39 »
It can be related to an outdated firmware revision of your ST-Link, too.
« Reply #19 on: 02. September 2020, 17:18:55 »
The fault was the old program on the new one is OK thank you
« Reply #20 on: 03. September 2020, 08:18:42 »
Is it possible to block the STM32H743ZIT6U?
I changed the settings:
1) Target / Option bites ....
2) Target / MCU Core ...
I'm loading firmware, bootloader and firmware (it's OK) and TRX won't start.
I replaced the processor and now it's OK.
« Reply #21 on: 03. September 2020, 08:37:33 »
Because on the old program I could not upload the bootloader
and I thought it was a setup problem (bites and MCU Core).
« Reply #22 on: 03. September 2020, 09:35:37 »
The problem of "scrambled option bytes" is present on F7 and H7 MCUs. The reasons are not 100% identified. If the option bytes are scrambled you can only access MCU via ST-Link. First you must perform a "complete erase", then reset option bytes manually to the default ones. critical are the reset vector bytes  BOOT_ADD0 and BOOT_ADD1. If these are acrambled MCU does nothing more than power consumption and listening to ST-Link
« Last Edit: 09. September 2020, 14:19:47 by DF8OE » Logged
« Reply #23 on: 09. September 2020, 12:22:54 »
I stepped into the same trap when soldering one of the first I40 UI boards:
https://www.amateurfunk-sulingen.de/forum/index.php?board=15;action=display;threadid=577;start=315
But with ST-Link and Andreas list of the correct option byte settings:
https://www.amateurfunk-sulingen.de/forum/index.php?board=15;action=display;threadid=577;start=285
it can be easily restored.
« Last Edit: 09. September 2020, 12:23:26 by peter_77 » Logged
Pages: 1 [2] Go Up Print
