Tests et diagnostiques OVI40 RF board
Symptôme: pas de r´ception sur aucune bande
Note: ToDo: Dans le text suivant adapter les numéros des composants au numéros OVI40 RF board, une fois le schéma est publié
If there is no sound when touching the base of Q1 there certainly is a hardware problem. This could also have something to do with the mixer or local oscillator. In case there is also no sound when touching the collector of Q1then this indicates a mixer problem, an issue in the subsequent operational amplifier or or in the audio codec including its switching mimic. Since the signal path after the mixer is low frequency audio this can also simply be verified by touching with a finger for initial empirical testing.
