02. May 2024, 00:38:37
Diskussions- und Newsboard des DARC-Ortsverbandes I40  |  allgemeine Kategorie  |  OVI40 SDR Projekt (English AND German discussions around OVI40 SDR project) (Moderators: DF8OE, DL1PQ)  |  Topic: Auffälligkeiten in der letzten Betarunde <- zurück vorwärts ->
Pages: 1 [2] Go Down Print
   Author  Topic: Auffälligkeiten in der letzten Betarunde  (Read 5600 times)
Re:Auffälligkeiten in der letzten Betarunde
« Reply #15 on: 31. October 2017, 14:16:17 »
Ist auf den Beta-Platinen nicht sogar ein 0-Ohm Widerstand und ein Jumper vorgesehen um die eingelötete Batterie ohne Probleme mal kurz elektrisch abklemmen zu können?
« Last Edit: 08. November 2017, 20:01:30 by DL8EBD » Logged
Thomas
Co
« Reply #16 on: 08. November 2017, 13:32:28 »
Hello all,
Have a problem in the UI pcb. Have done the 'smoke' test ,no problem. With lcd inserted the current flow is approx. 150 ma (firmware or bootloader not yet loaded).
I found however that the power is missing on pin 1 of both codecs. The 3v3 for the pull ups  for I2C for the codecs is present as well as A_3v on pins 8/14 of the codecs. IC6 ok.  Although no physical damage is found I  fear there is some broken power line on the pcb. Will add some hard wiring.
Co
« Reply #17 on: 08. November 2017, 13:55:39 »
Hi Co,
digital 3.3V is produced on ui PCB with small regulator. Analog 3.3V comes from rf PCB (there is another 3.3V regulator). If rf board is not connected analog 3.3V is missing.
Co
« Reply #18 on: 08. November 2017, 14:20:15 »
Hello Andreas,
No RF board connected, only 5v on pin 28/jp1 and gnd at pin 30. The 5v goes to IC6 giving 3v3. Secondly there is IC3 also supplying 3v3. According to the schematics (sheet 1/4) this supplies A_3V. IC3 is on the UI board. So it explains , the analog part of the codec gets power, the digital part only when RF board connected.
thank you
Co
DL1KBX
« Reply #19 on: 18. November 2017, 19:45:38 »
Moin,
habe heute festgestellt, dass ich zu unfähig bin um mein Kombi
mcHF 0.6 zusammen mit OVI40 zum Senden nicht nur ausserhalb von AFu-Bändern
überreden. Andersrum wäre mir egal, aber so...
« Reply #20 on: 18. November 2017, 20:13:31 »
Hi Wlad,
Mmmhhh...was meinst du denn genau mit dieser etwas kryptischen Feststellung. Ich betreibe hier ein I40 ver 1.6 und ein ver 1.7 völlig problemlos an einem ver 0.6er RF Board mit RX und TX.
Klappt auf Anhieb und fehlerlos ohne irgendwelche Kinken.
Ist dem RF doch eigentlich völlig "Latte" welches UI draufsteckt.
Wenn man mal von Goodies wie pseudo Stereo Empfang usw. absieht was nur das I40 kann.
Gleiche Konfig natürlich vorausgesetzt. Das du die ganzen Setups mit dem UI wechselst dürfte ja klar sein.
« Last Edit: 18. November 2017, 20:19:36 by peter_77 » Logged
DL1KBX
« Reply #21 on: 18. November 2017, 20:21:04 »
Hallo Peter
OVI40 Ver.1.7
6999 KHz - sendet. Kann aber auch ausschalten
7001 KHz - sendet nicht
FW 2.7.0
Eher irgendwas im Menü, finde aber nicht
« Reply #22 on: 18. November 2017, 20:23:05 »
Huch! das hört sich ja an, als ob die Funktion "TX on Out-Of-Band Freq" im Config Menü bei dir genau anders herum funktioniert.
Ich habe hier auch gerade eine Kombination ui-I40_V1.6 mit rf_V06 in Betrieb. Habe gerade mal mit der obigen Funktion herumgespielt. Das Ergebnis sieht durchwachsen aus. Bei 80 m ist oberhalb von 4 MHz tatsächlich kein Senden möglich, wenn die Funktion auf "Off" steht. Bei höheren Bändern, z.B. 30 m wird nur die Leistung reduziert, wenn man aus dem Band dreht und dann "Gen" in der Anzeige steht.
Aber innerhalb der Bänder sendet bei mir das Ding immer.
Edit: FW 2.6.0
« Last Edit: 18. November 2017, 20:25:24 by DF5LI » Logged
« Reply #23 on: 18. November 2017, 20:26:48 »
Als gesetzestreuer Funkamateur hatte ich jetzt auch immer innerhalb der Bandgrenzen gesendet
Muss ich glatt mal an der Dummy checken was außerhalb so passiert.
« Last Edit: 18. November 2017, 20:27:24 by peter_77 » Logged
DL1KBX
« Reply #24 on: 18. November 2017, 20:44:50 »
Quote from: peter_77 on 18. November 2017, 20:26:48
Ich habe sogar nie CB gemacht, aber...
Also genauer passiert bei mir folgendes:
Im Band kommt kein Mithörton und auch keine Leistung raus
Dabei sehe ich dekodierte Zeichen wenn ich mit der Taste was gebe und auch die rote LED geht an, das gleich auch
wenn ich TUNE einschalte
Werde noch mal die Platine unter die Lupe nehmen, vllt. ein Hardware Fehler bei mir, obwohl daran glaube
ich kaum
P.S. Habe mal nach dem Einspelen der FW alle alte Einstellungen gelöscht und neu  eingestellt
DL1KBX
« Reply #25 on: 18. November 2017, 21:19:02 »
E N T W A H R N U N G
Die PA war nicht abgegliechen. Sobald alles eingestellt lief auch der Mithörton und
auch die Leistung.
Komischerweise für Senden ausserhalb braucht man diese Einstellungen nicht machen
(wahrscheinlich für spätere Erweiterungen so gedacht?) deswegen auch so ein Algorithmus
Also Entwahrnung und wie man so sagt: Ende gut - alles gut!
Pages: 1 [2] Go Up Print
