Pages: 1 [2]
Topic: (SOLVED) OVI40 repair question (Read 4971 times)
WD8BXS
Re:OV140 repair question
« Reply #15 on: 10. September 2018, 23:41:43 »
I just jumpered P6 and tried to load the bootloader, but still just white screen, no USB acknowledgement
Chuck
Thanks, De WD8BXS vy 73
WD8BXS
Re:OVI40 repair question
« Reply #17 on: 11. September 2018, 15:12:55 »
I do have the ST-Link Andreas, read the previous posts please.
What would you have me do next to figure this out??
Can I load bootloader / firmware with st-Link.
What next please!
TNX de Chuck WD8BXS
« Reply #19 on: 11. September 2018, 15:57:22 »
yes, someone with an OVI40 F7 and ST-Link and Windows and STM32-Link should post a screenshot. I currently have no access to my OVI40 F7. Chuck, meanwhile it would be worth trying "Target"->"Erase Chip" (or simply CTRL+E), it might now do the trick to reset everything to default.
WD8BXS
« Reply #20 on: 11. September 2018, 17:30:55 »
Now I am very confused, are you not reading my previous posts?? I have already used the target erase chip.
After I did that I tried to load the bootloader and all I get is white screen, no LED's
Chuck
WD8BXS
« Reply #22 on: 11. September 2018, 17:45:30 »
OK Andreas, I understand. I will try to look for a topic that may help.
Chuck
« Reply #23 on: 11. September 2018, 20:59:40 »
Hi Chuck,
Chuck
I do read you posts. I know that you did the Erase, which did not work, then you used the "Option Byte" to change read out protection. And I did not knew that you tried "Chip Erase" after changing the read out protection. If you did, was not clear from your posts...
Anyway, I read the reference manual again (and again) and I would say, there might by no point in actually doing the Chip Erase. Resetting the option bytes is not part of the "Mass Erase" operation. However, it might be the case that "Chip Erase" does not only do a Mass Erase of the Flash memory, the STM32 Link Utility documentation is not clear on that.
So your best bet is to get the boot address set correctly in the option bytes and all the other settings.
« Last Edit: 11. September 2018, 21:03:42 by DB4PLE » |
WD8BXS
« Reply #24 on: 11. September 2018, 22:44:15 »
Thanks Danilo,
I do not know how to do that , so I will wait to see if someone posts how.
I do have a laptop that can run linux, so If I had instructions I could use that.
Chuck
WD8BXS
« Reply #25 on: 11. September 2018, 23:27:51 »
I have searched as well, and see no reference to resetting the vectors.
Is there just a file I can load to do that?
Chuck
« Reply #27 on: 12. September 2018, 10:42:04 »
Maybe its a register problem...?! Some I40 builders faced the same problem here when the MCU somehow scrambled the internal register setting. Take a look here: https://www.amateurfunk-sulingen.de/forum/index.php?board=15;action=display;threadid=577;start=315 You should better check the MCU option byte settings with the ST-Link if they have the approriate values like Andreas posted: https://www.amateurfunk-sulingen.de/forum/index.php?board=15;action=display;threadid=577;start=285
Read Out Protection: Level0 BOR-Level: Level3 IWDG_SW: checked WWDG_SW: checked nRST_STOP: checked nRST_STDBY: checked FZ_IWDG_STOP: checked FZ_IWDG_STDBY: checked nDBOOT: checked nDBANK: NOT checked BOOT_ADD0: 0x0080 Boot from 0x200000 BOOT_ADD1: 0x0040 Boot from 0x100000 |
| No checkmark set at all "Flash Section Protection" checkboxes !
This should definitely make the DFU mode working again. Then you need to set jumper P6 and fire up the DFUSe tool again and flash the bootloader and firmware ! Make sure you have the .dfu files here (NOT the .bin !!) for both bootloader and firmware ! That should bring the I40 UI back to life.
« Last Edit: 13. September 2018, 11:56:03 by peter_77 » |
WD8BXS
« Reply #28 on: 12. September 2018, 13:45:46 »
I reloaded registers, as listed with St-Link
Jumpered P6, and was able to load bootloader with dfuse removed P6 Loaded firmware with USB, worked as normal removed USB, radio came on to boot screen and stayed there. Unplugged and reconnected power, now when I hit power button, just white screen.
Chuck
WD8BXS
« Reply #29 on: 12. September 2018, 13:52:10 »
Well, I put P6 jumper back in and reloaded bootloader AND firmware with the DFuse, and now all is well!!!
Thanks to all who helped out!
Chuck
Pages: 1 [2]
