OE3HKC
Re:mcHF / Sparrow etc. mit externer PA
« Reply #32 on: 26. August 2019, 19:47:01 »
TNX, and here for the rest of Monday a current design from the mixer booard MiniMIXC, with adjustable band sections (B0,B1).. vy 73, Helmut
OE3HKC
« Reply #34 on: 27. August 2019, 12:13:41 »
Hallo, today morning I did some measures with my good old battleship FSAS from Rhode, it is about 30 years old but only with a centronics interface for old printers and plotters.. I'll publish my results in the following post, but please don't worry about the bad quality of pictures..
as first my old analyzer equipment...
OE3HKC
« Reply #35 on: 27. August 2019, 12:32:12 »
condicions for all measures:
DUT is MiniTRX (not mcHF, only SW is the same...)
AF = 800Hz, -15dB into LineIN (L>L) signal measure point is after BP and LP (MiniFIL) == input from the pa pcb MiniPA... the PA is not activated to avoid undesirable couplings..
the first pix is from 80m band, span 125 kc, Xlate= -6kc..
you can see a 60 dB suppression from the LO-signal and a very good suppression from the mirror in 12 kc distance.. but there are signals +/- 48 kc left and right from the working frequency.. perhaps the FFT signal for spectrum display and waterfall??
OE3HKC
« Reply #36 on: 27. August 2019, 12:36:43 »
and now for compare a pix without Xlate under otherwise the same condiciones..
only the +/- 48 kc-signals are visible...
OE3HKC
« Reply #37 on: 27. August 2019, 12:44:23 »
now the same signal 15 kc around the working frequency..
first with Xlate -6 kc... you can see on the left side the harmonics with 50 dB distance from the signal amplitude and the LO leakage signal with a distance from 60 dB...
the undesired sideband has a good suppression von > 70 dB...
OE3HKC
« Reply #38 on: 27. August 2019, 12:48:27 »
sideband suppression is only >50 dB, harmonics from the AF signal >50 dB
OE3HKC
« Reply #39 on: 27. August 2019, 13:09:12 »
and now a smaller span from 4 kc, first with Xlate -6 kc... you see the very good carrier and sideband suppression >70 dB
OE3HKC
« Reply #40 on: 27. August 2019, 13:11:44 »
under same condicions, but without Xlate...
carrier suppression <60 dB, udesired sideband 54 dB...
OE3HKC
« Reply #41 on: 27. August 2019, 13:17:54 »
but there are bad condicions on the higher bands, e.g. the 15m-Band...
the following pix shows the spectrum for a 21,3 Mc signal, span is 125 kc, Xlate -6 kc the LO leakage suppression is very poor with only 40 dB, mirror suppesion is high with 90 dB...
OE3HKC
« Reply #42 on: 27. August 2019, 13:19:19 »
the same with Xlate off looks very better...
OE3HKC
« Reply #43 on: 27. August 2019, 13:21:46 »
the same signal in closer distance (15 kc) around the working frequency first with Xlate -6 kc...
OE3HKC
« Reply #44 on: 27. August 2019, 13:38:20 »
and without Xlate..
carrier suppression only 40 dB sideband suppression 60 dB and the advantage... the undesired spurious stay all near the working frequency... if I had to decide which mode produces more disorders (also in QRP mode) I would pick the Xlate mode.. especially for SSB transmitting... nobody transmitts in AM, CW is no question, here is no Xlate necessary... or yes ??
in RX-mode it's no reason to switch off Xlate, but it is recommended to iuse a isolation preamp.. to hold far the LO leakage from the antenna...
vy 73, Helmut
