Topic: i40 white screen nach FW2.7.22 (Read 3232 times)
« on: 29. November 2017, 07:23:16 »
@Andreas, nach 2-maligen Flashen der FW von heute (2.7.22) jeweils nach dem Einschalten - "White Screen": Rückführen auf 2.7.21 klappte jeweils problemlos, danach Funktion i. O. flashen via Stick. Schau bitte mal nach vy 73 aus Erfurt Michael_K
Co
Re:i40 white screen nach FW2.7.22
« Reply #2 on: 29. November 2017, 08:41:52 »
Hello Michael,
Just loaded 2.7.22 using STLink. No problems here i40 starting up correctly.
regards
Co
« Reply #3 on: 29. November 2017, 08:56:48 »
Hallo Michael und andere,
falls es da Probleme gibt, einfach auf 2.7.21 zurück gehen und warten. Heute abend werfe ich dann meinen OVI40 mit dem 3.2 Display an und schaue. Vorher wird da vermutlich nichts passieren, und mit hoher Wahrscheinlichkeit ist eine meiner Änderungen schuld.
« Last Edit: 29. November 2017, 09:08:08 by DB4PLE » |
« Reply #5 on: 29. November 2017, 09:49:23 »
Just flashed the .22 onto ver. 1.7 UI with 3.2" lcd (source Waveshare) and switches it off and on several times. No issues with the screen !
Only thing i oberserved, as Thomas mentioned too, is the more "nervous" spectrum and noise display (I40 only) over the last 5 releases.
« Last Edit: 29. November 2017, 09:53:27 by peter_77 » |
« Reply #6 on: 29. November 2017, 10:28:25 »
Hi Peter,
The more nervous one comes from the fact that you now actually control the frame rate quite accurately (up to the point where it cannot go faster, more visible with the waterfall). Before that you controlled the duration of the pause between each of the 5 calculation steps. And with that, the meaning of the speed factor changed. In theory, same speed setting on OVI40 and mcHF should now result in the same speed (that works for lower speeds quite well). However, the mcHF of course looses once we come to the performance limits. BTW, updates per second = 30/speed.
Co
« Reply #7 on: 29. November 2017, 10:35:18 »
Peter,
I also checked the "scope speed" in 2.7.22 . The speed can be adjusted again via the menu. I don't know whether the menu value vs. speed is the same as in the older versions.
Regards
Co
edit : apparently I doubled with Danilo.
« Last Edit: 29. November 2017, 10:37:44 by Co » |
« Reply #8 on: 29. November 2017, 13:00:55 »
die D2.7.22 läuft bei mir und ich habe das 3,2" Display dran.
« Last Edit: 29. November 2017, 18:29:26 by DL8EBD » |
Re:i40 white screen nach FW2.7.22/Entwarnung
« Reply #9 on: 29. November 2017, 19:11:31 »
den UHSDR OV i40 einmal quer durch Erfurt "gekarrt" (zum OV-Nachmittag), ujnd er läuft auch mit der FE 2.7.22. Einzige Änderung zu heute Vormittag: anderes Netzteil zur Stromversorgung, aber gleichfalls stabile Steckverbindungen. Somit aus meiner Sicht: keine Arbeit für die SW-Entwickler vy 73 aus Erfurt und noch einen schönen Abend Michael_K
