ovi40test:uiboardtest [18.01.2018 23:59] – df9ts | ovi40test:uiboardtest [21.03.2018 07:35] – [WM8731 not detected] dg8ygw | ||
- | die MCU hat zwei (!) Pin 1 Markierungen | ||
- | [{{: | + | ==== EEPROM IC7 Einbau Lage ==== |
+ | die MCU hat zwei (!) Pin 1 Markierungen < | ||
Zeile 15: | Zeile 22: | ||
- | ==== MCU wiederbeleben ("bricked MCU") ==== | + | ==== "WM8731 not detected" |
- | If something strange or unexpected happened to your board and none of the usual procedure are working to install the Bootloader or the Firmware, this might bring life back into your UI. | + | |
+ | * CPU Takt (→ TXCO Takt messen) | ||
- | You will need : | + | Buttons, LEDs und LCD sind da noch nicht initialisiert. Erst wenn der Bootloader installiert wurde und läuft hat man minimalistisch die Peripherie-GPIOs initialisiert, |
- | - an up to date STM32 ST-LINK utility ( http://www.st.com/ | + | |
- | - a ST-LINKV2 probe ( http://www.st.com/ | + | |
- | - latest version of the Bootloader and/or UHSDR Firmware | + | |
- | The only tricky part is to connect the probe JTAP connector to the JP8 UI board, here are the needed wires : | + | Bei installiertem Bootloader: |
- | JP8-3 (SWDIO) to JTAG-7 | + | * Taste " |
- | JP8-4 (SWCLK) to JTAG-9 | + | * Taste "Band +" drücken, dann OVI40 UI board hochfahren ⇒ Boot Loader Update via kleine USB Buchse |
- | JP8-5 (UI_3V3) to JTAG-1 | + | |
- | JP8-6 (GND) to JTAG-20 | + | |
- | The rest of the procedure is straight forward | + | Prüfen: |
- | One additional trick, when I first connected to the MCU, I got an error message « Readout Protection Mode » and was unable to erase the chip. I finally choosed to try to flash a first time and the utility did what was necessary | + | * erkennt der PC das per USB angeschlossene OVI40 UI board (Gerätemanager / Device Manager)? |
+ | * Check all MCU pins are correctly soldered and no shortcuts exist: Use a thin knife / scalpell / tweezer, go inbetween | ||
- | [{{: | + | ==== NF Audio Verstärker geht nicht ==== |
- | A couple of us faced the same issue during beta testing the new UI board. | + | Bitte +12V Versorgung des NF Audio Verstärkers messen. Er wird vom OVI40 RF Board über P1 versorgt. |
- | But as you could see a cheap chinese ST Link adapter from Amazon or eBay saves your day | + | |
- | Here are the steps. Unfortunately in German but maybe it helps. | + | ==== USB Stick funktioniert nicht ==== |
- | https:// | + | |
- | Register values from Andreas: | + | |
- | The URLs are from a (forgotten) I40 UI thread in the mcHF folder. | + | Bitte +8V Versorgung von RF Board prüfen, JP1 (Pin29). |
