Differences
en:uhsdr_dev:segger_j_link [27.02.2018 05:47] – df9ts_user | en:uhsdr_dev:segger_j_link [27.02.2018 07:38] – df9ts_user | ||
Line 1: | Line 1: | ||
- | Segger | + | ==== Segger |
+ | Segger | ||
Segger supports the Cortex M7 SWV interface used on OVI40 UI and offers plug-ins for MCU eclipse. | Segger supports the Cortex M7 SWV interface used on OVI40 UI and offers plug-ins for MCU eclipse. | ||
- | For Debug output Segger offers two options in MCU eclipse: | + | For Debug output Segger offers |
* TRACESWO output as defined by CORTEX M7. This requires a dedicated pin, currently used for M3 pushbutton switch | * TRACESWO output as defined by CORTEX M7. This requires a dedicated pin, currently used for M3 pushbutton switch | ||
- | * Segger Real Time Tracing (RTT) with outputs debug messages in high speed via SWV debug lines (CLK and SWData). No need for an additional line to printout debug messages | + | * [[https:// |
+ | The J-Link makes use of the Cortex-M feature, which allows accessing the memory via the debug interface while the target is running. | ||
+ | How this works in general is described [[https:// | ||
The speed advantage of RTT - according to Segger data - is impressive: | The speed advantage of RTT - according to Segger data - is impressive: | ||
Line 82: | Line 87: | ||
- | ==== Converting on-board ST-Link On-Board into J-Link On-Board ==== | + | ==== Get to know J-Link: |
- | Fpr experiments with J-Link (not related to OVI40, but in order to get to know J-Link HW & SW) the on-board ST-Link board of those boars can be converted to J-Link, see [[https:// | + | * Certain STM32 development boards contain an ST-Link probe. |
+ | * For experiments with J-Link (not related to OVI40, but in order to get to know J-Link HW & SW) the on-board ST-Link board of those boars can be converted to J-Link, see [[https:// | ||
+ | * Compatible STM32 that can be re-flashed are listed | ||
