Lapwing support of UHSDR
« on: 18. October 2019, 18:43:33 »
Hi
« Last Edit: 29. June 2022, 21:02:45 by SP3OSJ » |
positron alter Hase
Re:Baubericht: UI mit 480MHz STM32H743ZIT6U
« Reply #1 on: 18. October 2019, 20:58:30 »
I have no problem showing what I'm doing now.
So do I...
Hi all, the heart of my solution is fully functional, all bands RX and TX with good results. Full duplex receive/low power transmit on HF, 6m, 4m, 2m. Fpga resources usage level <49%, which means plenty room for second receiver in the future. Ths is very time consuming process - ordinary hardware development: idea, simulation, verification in circuit, measurements and again simulation and so on... It is not so simply as copy and paste. Also a lot of work with fpga development. Now designing the rest of the boards and case.
Example receive on 2m:
and of course working board:
positron alter Hase
« Reply #2 on: 19. October 2019, 07:55:18 »
now I know why Artur cleans his desk so pedantic, noone is able to hook up on details, sorry I don't have time for this...
Thomas - yes the medicine for soldering iron: just H2O but wiped out a bit
Medicine.JPG « Last Edit: 19. October 2019, 07:57:09 by SP9BSL » |
« Reply #3 on: 19. October 2019, 08:55:52 »
Sage mal Thonas woher hast du die MCU bezogen habe hier auch noch 1.8 Bord unbestückt zu liege und da kommt man dann schon ins überlege
Lg BO_Andy
« Reply #4 on: 19. October 2019, 09:08:57 »
von Mouser... aktuell 65 am Lager https://www.mouser.de/ProductDetail/511-STM32H743ZIT6U
« Reply #5 on: 19. October 2019, 09:25:45 »
Der Preis geht aber mal gucke ob ich jemanden finde der bei mouser eh bestellen muss bzw mehr Brauch wie ich. Die 13 Euro wäre es mir auf jeden Fall wert.
Lg BO_Andy
« Reply #6 on: 19. October 2019, 09:30:43 »
Andy, habe ich schon oft empfohlen:
https://www.mikrocontroller.net/topic/464480#new
erstes Posting vom David beachten, bzw. dem Wiki Artikel folgen....
« Last Edit: 27. October 2019, 18:06:33 by DL8EBD » |
« Reply #7 on: 19. October 2019, 11:13:40 »
Danke für denn Tipp Thomas ich ringe grade mit mir ob ich wirklich nochmal ein mchf aufbaue. Habe ja noch ein umbestückte Platinensatz 0.4 hier liegen oder ob ich warte bis die platinen fürs OVI 40 kommen
« Reply #8 on: 19. October 2019, 11:18:45 »
Andy, bedenke dass diese H7 CPU noch keinerlei Vorteile bringen wird.... Die Performance wird von der Firmware gar nicht ausgereizt. Selbst für den 400MHz Vorgänger nicht. Das ist erst mal lediglich ein Versuch...
Ganz ehrlich, ich würde nicht mehr in einen mcHF investieren. Zu viele Kompromisse....
« Last Edit: 27. October 2019, 18:06:58 by DL8EBD » |
dl2eea
Ich liebe meine Frau!
« Reply #9 on: 19. October 2019, 14:05:02 »
You can see that Slawek works hard and the results of his work are not strictly secret! Well done Slawek! Hope is in you. 73 Josef
« Reply #10 on: 19. October 2019, 21:58:06 »
Ganz ehrlich, ich würde nicht mehr in einen mcHF investieren. Zu viele Kompromisse.... Baue lieber einen SParrow und verkaufe die 0.4er Leiterplatten.
| Thomas irgendwo hast du recht aber wenn dann würde lieber denn Lapwig bauen . Frage ob der überhaupt schon erhältlich ist
« Reply #11 on: 19. October 2019, 22:17:03 »
Andy, Du weißt, dass der Lapwing nur 23cm kann?
« Last Edit: 27. October 2019, 18:05:54 by DL8EBD » |
« Reply #12 on: 20. October 2019, 16:30:17 »
Das ist mir bewusst Thomas aber für denn Bandberreich habe ich ja dann schon 3 andere Geräte Tulipan OVi 40 sowie denn PSDR. Denn mchf Besitze ich nur noch als Leerplatine.
Lg BO_Andy
« Reply #13 on: 22. October 2019, 01:09:56 »
Wann ist er erhältlich? ....dazu hat Artur weiter oben etwas geschrieben....
TRX Lapwing ist fertig, Artur kann allerdings den Sender nicht richtig testen.
Warum? Weil sein Konzept so aussieht dass die I40 UI irgendwo um 30 MHz bis 40 MHz TX seitig arbeiten muss. Leider ist es in der Firmware so eingerichtet, dass oberhalb 29xxx kHz keine signifikante Leistung mehr raus kommt. Artur sucht jetzt eine Firmware Version wo diese Verriegelung des Senders fehlt. Ich hatte mal angefangen im Quelltext danach zu suchen um ihm eine Testversion zu kompilieren - bin da aber auch nicht richtig weitergekommen, auch weil die UHSDR zu der Zeit ständig in Bewegung war. Vielleicht kann ich das jetzt nochmal in Angriff nehmen weil momentan keine neuen Versionen erscheinen.
Ja, werde ich mal machen....
Es ist inzwischen trivial, die Bandbereich neu zu definieren. Das wurde hier im Forum von mir auch schon beschrieben. Wenn man die Firmware kompilieren kann, dann sollte es einfach sein.
Und der Lock ist schon ewig drin, beim Suchen nach einer Binärversion ohne Lock wünsche ich Artur viel Erfolg, sehe da aber keinen Sinn drin, siehe oben.
OE3HKC
« Reply #14 on: 22. October 2019, 05:04:42 »
... und den Tiefpass im Sendeweg mit fc von ca 32 MHz würde ich auch nicht außer Acht lassen.... oder wurde der etwa schon geändert?
Vy 73, Helmut
