11. July 2025, 02:16:57
Diskussions- und Newsboard des DARC-Ortsverbandes I40  |  allgemeine Kategorie  |  UHSDR Firmware (Moderators: DF8OE, DL1PQ)  |  Topic: Lapwing support of UHSDR <- zurück vorwärts ->
Pages: 1 [2] Go Down Print
   Author  Topic: Lapwing support of UHSDR  (Read 9359 times)
Re:Baubericht: UI mit 480MHz STM32H743ZIT6U
« Reply #15 on: 24. October 2019, 17:19:30 »
This is because of the different Lo/Rx - Freq relationship. Your hardware must be integrated properly so that translation is as it is choosen. I do not have nothing against integration of your hardware support to the main branch - if you publish a schematics so that it is "Open Source". Maybe the full support last some time - but actually software development is calm (waiting for the new RF boards). I am nearly sure development speed will raise again if RF boards are available and that can be the point to discuss how an integration can be realized. For this moment you can hope someone compiles you a "personal edition"
« Reply #16 on: 24. October 2019, 17:20:40 »
This is caused by frequency calculation in touchscreen function, probably transverter offset not added to freq calculation. AFAIK users not frequently uses transverter mode due to mcHF mixer issues. Make "to do" list and me or other correct this in spare time.
@Andreas: yes, this can be of course, first we need to define structure for RF hardware of our boards. I'm sure, this will happen quite soon
« Last Edit: 24. October 2019, 17:23:49 by SP9BSL » Logged
« Reply #17 on: 24. October 2019, 20:58:04 »
out of curiosity I did also an attempt to add LAPWING support to the UHSDR firmware, following my own recommendations I posted here.
Looking at the current amount of changes, I don't see why we could not integrate this into the normal build.
See here: https://github.com/db4ple/UHSDR/commit/14367aadc05a77fce8f1dd84694c4629feb86f47
A couple of things could be a little bit more refined, such as the frequency display (we should leave less space around the dot separating the 3 digit groups). But this would also be a benefit for the non-Lapwing builds.
Most notably the calculation of the Si570 frequency from the dial frequency (Si570_translateExt2Osc) in osc_si570.c is not correct, but Artur should be able to provide the correct formula. Once this is done, it should more or less work OOB.
Of course one has to disable all transverter settings, as this is a native 23cm configuration. It is also necessary to set the PA calibration value for 23cm @ 5W and FULL.
« Reply #18 on: 25. October 2019, 06:13:37 »
Hi Artur,
that is in fact the formula I already used.
@DF8OE: Shouldn't we separate this discussion from the original Baubericht?
Pages: 1 [2] Go Up Print
