Topic: Please upgrade your UHSDR bootloaders to 5.0.1 (Read 2908 times)
« on: 23. November 2018, 22:33:26 »
EDIT: H7 owners: Please wait until updating the bootloader! 5.0.1 has a serious issue, which disables the DFU update capabilities. This applies to STM32H7 based TRX only, mcHF and Co, as well as OVI F7 can use 5.0.1. Sorry!
EDIT EDIT: 5.0.2 is out and works on all machines including H7 as expected.
we discovered yesterday a serious issue in our UHSDR bootloader code. This wrong code may have caused many different interesting issues (not booting machines, crashes when using zoom and probably many others) when running any firmware. It potentially affects all firmware versions we ever released.
To be clear, the problem is in the bootloader, but affects the firmware. For details read https://github.com/df8oe/UHSDR/issues/1610#issuecomment-441123556 . It potentially affects all machines running the UHSDR bootloader using STM32F4xx (mcHF, Eagle, ... ), STM32F7xx/STM32H7xx (OVI40, Sparrow, ... ) processors.
We release a fixed bootloader 5.0.1 to solve that issue. Upgrading the bootloader is described here:
https://github.com/df8oe/UHSDR/wiki/Bootloader-Installation
BTW, those running the original M0NKA bootloader may or may not be affected by a similar issue, we simply don't know and will not investigate this either. So it is up to you entirely if you replace these bootloaders.
Anyway, since this bootloader issue may have unexpected impact, please upgrade to the newest bootloader before reporting firmware issue. Thank you!
Newer firmware will check if you are running a fixed bootloader and ask you to upgrade if you are running an older UHSDR bootloader version. Yes, it is that serious.
« Last Edit: 24. November 2018, 08:18:16 by DB4PLE » |
Re:Please upgrade your UHSDR bootloaders to 5.0.1
« Reply #1 on: 23. November 2018, 23:02:36 »
Bootloader 5.0.1 auf dem SParrow mit H7 über DFU geflasht. Funktioniert.
Dann D2.9.74 über USB-Stick geflasht - SParrow hängt dann, kein automatischer reboot durch Ziehen des Sticks oder Drücken von Band Minus => keine Wirkung (Aufforderung auf dem Display nach Finished erscheint aber). Muss die 12V einmal trennen, danach läuft er er mit der aktuellen Firmware normal
« Last Edit: 23. November 2018, 23:08:13 by DL8EBD » |
« Reply #2 on: 23. November 2018, 23:15:09 »
danke fürs Testen. Niemand sagt, dass der Bootloader fehlerfrei ist. Wenigstens geht er bei Dir. Bei mir werden auf dem H7 leider keine USB Sticks erkannt und DFU geht auch nicht. Da werde ich wohl nochmal ran müssen.
« Reply #3 on: 24. November 2018, 00:19:25 »
for all who already flashed the bootloader 5.0.1 on a STM32H7 based machine (and only for those): I broken the DFU update in 5.0.1, so please accept my apologies and open the TRX, set the P6 jumper and flash the 5.0.2 bootloader once Andreas released it. Of course, the ST-Link can be used as well...
Yes, quality control was a little bad today. I thought I had tested it sucessfully on the 5.0.1, but this was on 5.0.0 and of course, I did a mistake in 5.0.1
« Last Edit: 24. November 2018, 00:20:09 by DB4PLE » |
« Reply #5 on: 24. November 2018, 08:02:12 »
Bootloader 5.0.2 auf dem SParrow mit H7 über ST-Link geflasht. Funktioniert.
Dann D2.9.74 über USB-Stick geflasht - automatischer reboot durch Ziehen des Sticks oder Drücken von Band Minus funktioniert nun.
SParrow läuft normal.
Bootloader 5.0.2 auf die OV-I40 V1.8 UI mit H7 über DFU Mode geflasht. Funktioniert ebenfalls
Von meiner Seite aus kann ich sagen dass es auf dem H7 jetzt mit dem 5.0.2 funktioniert. Ist auch unter den System-Infos korrekt eingetragen
Danke Danilo, Andreas und den Softwerkern
« Last Edit: 24. November 2018, 08:16:31 by DL8EBD » |
« Reply #6 on: 26. November 2018, 13:39:31 »
Same here... H7 (SParrow) and F7 (I40) update to 5.0.2 without any issues. Booting and functions all error free. Same with the now as well available 5.0.2 bootloader for mcHF ! Thanks a lot to the SW team for the good work !
« Last Edit: 26. November 2018, 13:39:56 by peter_77 » |
