03. July 2025, 02:48:15
Diskussions- und Newsboard des DARC-Ortsverbandes I40  |  allgemeine Kategorie  |  OVI40 SDR Projekt (English AND German discussions around OVI40 SDR project) (Moderators: DF8OE, DL1PQ)  |  Topic: Final RF (RX/TX) PCB Prototype populating history (Sep 10.-18. 2021) <- zurück vorwärts ->
   Author  Topic: Final RF (RX/TX) PCB Prototype populating history (Sep 10.-18. 2021)  (Read 8705 times)
« on: 10. September 2021, 16:20:41 »
Sep 10, 2021:
This week I got the prototype PCBs (final layout) for OVI40 RF (RX/TX) from manufacturer. It is a six layer PCB and I am very exited if everything is working. Today I started with FPGA (and checked if all balls are connected: they are - and no short circuits). This weekend I will populate more and more parts, every step checking if everything works as expected.
I have already tested all blocks on former intermediate prototype PCBs (shortwave RX/TX block works for nearly a year). AD9363 has worked using Spartan FPGA, also USB interface. It is "new" to marry all blocks together on one PCB  . I hope they will iove each other and will result in a "perfect working team"...
I will report from time to time about the progress.
« Last Edit: 18. September 2021, 16:14:41 by DF8OE »
Re:Final RF (RX/TX) PCB Prototype populating has started
« Reply #1 on: 10. September 2021, 17:15:13 »
Super,
viel Erfolg bei der weiteren Arbeit.
testing FPGA (1)
« Reply #2 on: 11. September 2021, 11:29:09 »
Sep 11, 2021:
Everything mounted to program FPGA (top side)
« Last Edit: 11. September 2021, 11:39:07 by DF8OE »
testing FPGA (2)
« Reply #3 on: 11. September 2021, 11:29:48 »
Sep 11, 2021:
Everything mounted to program FPGA (bottom side)
« Last Edit: 11. September 2021, 11:39:22 by DF8OE »
testing FPGA (3)
« Reply #4 on: 11. September 2021, 11:31:15 »
Sep 11, 2021:
programming successfully finished
« Last Edit: 11. September 2021, 11:38:47 by DF8OE »
Re:Final RF (RX/TX) PCB Prototype populating progress (Sep 11. 2021)
« Reply #5 on: 11. September 2021, 12:15:20 »
Hallo Andreas....
TOP!!!
Re:Final RF (RX/TX) PCB Prototype populating finished on Sep 17. 2021
« Reply #6 on: 17. September 2021, 15:08:14 »
Sep 17, 2021:
Hi to all,
today I finished populating of OVI40-RF2. I have checked everything twice and more during populating, measured voltages and currents on several places / tracks.
Of course such a complex schematics (and because of netlist the resulting PCB, too) has some errors which I did not discover before PCBs are manufactured. But until now these are minor errors which can be corrected on the prototype PCBs - not necessary to manufacture new, corrected ones.
I already have transmitted on the shortwave block (10KHz...76.8MHz) and received using both ADCs. So this block can be declared as "not containing issues". Testing of VHF/UHF/SHF block will take some time because of I first must port the Spartan code to Altera. But all voltages and signals on AD9363 are looking fine, data lines are all checked so that I hopeully will confirm working of this stage in the next time.
« Last Edit: 17. September 2021, 15:26:53 by DF8OE »
Re:Final RF (RX/TX) PCB Prototype populating progress (Sep 17. 2021)
« Reply #7 on: 17. September 2021, 15:08:34 »
Sep 17, 2021:
« Last Edit: 17. September 2021, 15:27:07 by DF8OE »
Re:Final RF (RX/TX) PCB Prototype populating history (Sep 10.-18. 2021)
« Reply #8 on: 18. September 2021, 16:15:39 »
Today I build a simple adaptor PCB to marry RF2-Board and OVI40-UI_1.8...
« Reply #9 on: 18. September 2021, 16:16:02 »
« Reply #10 on: 18. September 2021, 16:16:16 »
« Reply #11 on: 18. September 2021, 16:17:04 »
Now FPGA firmware development can start
« Reply #12 on: 23. September 2021, 17:49:00 »
Sieht und hört sich ja gut an; unter andrem auch die weitere Nutzung des OVi40-ui-Boards (auch ich habe noch eins "rumliegen")
2, wenn auch nebensächlcihe Fragen:
1. wie sieht es mit der Kühlung der ICs aus? von anderen, ähnlichen Projekten sind mir "nicht unerhebliche Kühlkörper" im Gedächtnis.
2. eigentlich zum ui: wie sieht es da mit 4"-Display aus?
« Reply #13 on: 24. September 2021, 04:45:47 »
Weder auf der RF-Platine noch auf der UI-Platine muss irgendwas gekühlt werden. Das Gespann aus OVI40-UI mit 4" LCD und RF2 nimmt im RX man gerade 240mA auf. Mit 2 ADCs in vollem Betrieb und AD9363 aktiviert.
« Reply #14 on: 24. September 2021, 10:57:22 »
Danke an Andreas und Thomas für die Infos.
Die "thermische Frage" ist damit geklärt.
Ich möchte das eigentliche Thema hier nicht "mißbrauchen".
Könntet Ihr mir ein paar Infos zu 4" rüberschieben (Adapterplatine welches LCD). evtl. per PN
Danke
