14. July 2025, 19:34:47
Diskussions- und Newsboard des DARC-Ortsverbandes I40  |  allgemeine Kategorie  |  mcHF Projekt Deutsch / English (here you can discuss everything related to mcHF) (Moderators: DF8OE, DL1PQ)  |  Topic: stm32f4 vs stm32f7 compatibility <- zurück vorwärts ->
Pages: 1 [2] Go Down Print
   Author  Topic: stm32f4 vs stm32f7 compatibility  (Read 11301 times)
Re:stm32f4 vs stm32f7 compatibility
« Reply #15 on: 14. September 2017, 09:41:30 »
Hello Markus,
Quote from: dl8mby on 14. September 2017, 08:42:41
Sorry Danilo,
one final question ;-)
The FW inside the github for the old mchf and the new OV I40 UHSDR
compiles for both of the MC's F4 and F7 according to the switches inside
the Makefile - right?
It is a bit differently organized, but there are some switches in the Makefile. Have a look.
Means this that the FW code include a huge amount of #defines to brunch
during compil time through the hw specific code?
And I do not speak about the #defines inside the HAL but about the community
code developed by you and others.
Markus
By using the HAL we get away with a fairly well controlled amount of these switches, but yes there is a share of these
in the code in the places where the architectures of the TRXs differ, not so many really related to the F4 vs. F7. Not too many, since we try to keep this properly organized.
So even if both TRX variants would use the same microprocessor, these differences would exist.
The processor related differences are handled  below basesw/{mchf,ovi40} to 95% or something like that.
dl8mby
« Reply #16 on: 14. September 2017, 10:06:28 »
Dear Andreas,
I had noticed that there are switches inside the Makefile to distinguish
between the F4 or F7 hw. My question focusing on the effort to be done
to write code for both scenarios F4 (old staff) and F7 (the new one).
Is the C code divided in different paths separated by #defines or how
huge is the effort to maintain both architectures.
Markus
dl8mby
« Reply #17 on: 14. September 2017, 10:10:00 »
Sorry, Danilo had already answered my question.
Thanks a lot.
Markus
yo2ldk
I love SDR & OVI40 !
« Reply #18 on: 14. September 2017, 11:33:04 »
OK, now is clear - thank you all for clarification !
I wait for OVI40 , as I see, that will be much over mchf
as performance and development.
  BTW is some schematics file /info available or need to wait until is ready?
  Have you consider to use a little bit large screen, and maybe for a better audio coder/decoder, at least at 192kHz?
just some idea if is applicable to OVI40.
Vy 73,
de yo2ldk - Alex
    kn05WH
« Reply #19 on: 14. September 2017, 11:36:36 »
1. yes: 3.2" vs. 2.8" to keep the formfactor the same and also to keep the power consumption low)
2. No. However due to the separation of audio and iq codec (we have 2) we may go up to 96khz (this is max for WM9831) at some point.
« Last Edit: 14. September 2017, 11:37:20 by DB4PLE » Logged
« Reply #20 on: 14. September 2017, 11:42:28 »
You can find schematics (preliminary) here:
https://www.amateurfunk-sulingen.de/forum/attachments/mchf_ui_i40_15.pdf
...and 3D model here:
https://www.amateurfunk-sulingen.de/forum/attachments/UHSDR_ui_OVI40_17.pdf
...and photo of first prototype here:
https://www.amateurfunk-sulingen.de/forum/attachments/I40_ui.png
« Last Edit: 14. September 2017, 11:48:30 by DF8OE » Logged
yo2ldk
« Reply #21 on: 14. September 2017, 14:35:49 »
TY Andreas,
for the schematic; the 3D model i found it earlier.
Under LCD in right is a place for one more push button,
this can be used as memory switch mode, then the others
from left can become M1 to M5 (for CW, RTTY messages fro ex.)
or, maybe you have another good solution.
STM32F7 have so many I/O, so PCB can be a little high or longer,
but I see you keep it the mchf standard; even if OVI40 will be 85%
another transceiver.
73 de alex
Vy 73,
de yo2ldk - Alex
    kn05WH
« Reply #22 on: 14. September 2017, 15:04:20 »
Hi Alex,
yes: we want to be compatible with the 30p header used on mcHF. But we have additional headeres on our UI board - and the three buttons under the encoders do have different functions than the integrated buttons  in encoders. We do have one more button betwee power and BANDM. PCB is alredy in betatest state - so no more changings can be done now. But our project will consist of more than two PCBs. Please stay tuned
KevinA
It's English
« Reply #23 on: 04. October 2017, 03:15:31 »
Quote from: DB4PLE on 14. September 2017, 11:36:36
Has anyone done the math on sample size/sample rate/ MCU clock?
48Khz sample rate with 16 bit and 180Mhz clock F4xx (current)
96Khz sample rate with 32 bit and 216Mhz clock F7xx
192Khz sample rate with 32 bit and 400Mhz clock H7xx
What is gained with higher sample rates? What is gained with larger sample sizes?
If the MCU did nothing but DSP on the I/Q what could the maximum size and rate be?
Thanks
Kevin K2AAE
Kevin K2AAE
« Reply #24 on: 04. October 2017, 06:32:34 »
Hi Kevin,
using higher sample rates increases the range in spectrum / scope. Yaou can look at a wider span. We will do that oa OVI40 - it is probably not possible on mcHF because we are on the edge of RAM and audio interrupt, where important maths are done, would explode.
Using higher resolution (bits) does only produce  CPU load and increases RAm consumption. You do win in theory 3dB - in practise nothing.
KevinA
It's English
« Reply #25 on: 04. October 2017, 17:41:38 »
Another 'quick' question: What DSP processing is needed for the I/Q codec?
Kevin K2AAE
« Reply #26 on: 04. October 2017, 18:24:05 »
It is possible to start "a quick question" about this - but impossible to give a "quick answer". Math is complicated and complete answer would fill pages. You find some informaitons in GutHub WIKI about DSP and if that does not satisfy you the only quick possiblility is to look at the code...
But we will do a complete restructuring of DSP routines to WDSP the next months so I think it does not make much sense to dig into the actual DSP code...
Pages: 1 [2] Go Up Print
