Topic: I can't install modified firmware on my UHSDR-QRP transceiver v_0.6.3 (Read 3596 times)
LEO73
<Never a joy>
« on: 09. December 2024, 23:08:46 »
Hello to everyone, i tried to update firmware unfortunately transceiver not enter in maintenance mode.
I read, for a last version board, is not necessary install bootloader because new firmware will be inside the eeprom. However I'd like to load, inside transceiver modified 2.12.0 SatoryBoy(for CB frequencies) version but using old procedure is impossible! 1) insert on usb port pendrive with inside last modified firmware. 2) turn on transceiver pushing together "power on" button and "BAND-" button. Unfortunately transceiver not enter in firmware load mode but enter in display calibration, like the pictures. In old update manual there's wrote to close P6 jumper unfortunately in my board there is any juniper to close.
Here my board picture link: https://drive.google.com/file/d/1QbcNImXA6naD0_IJ8UnZ23lV5Gw7x1bP/view?usp=drivesdk
What is right procedure to update firmware please.
LEO73
<Never a joy>
Re:I can't install modified firmware on my UHSDR-QRP transceiver v_0.6.3
« Reply #2 on: 10. December 2024, 12:40:26 »
Dear Andreas, Thank you to your kindly reply, I went in your suggested links, I downloaded last DfuSeDemo + usb DFU ST7micro electronics driver unfortunately the ST7 USB DFU driver is not recognised by windows 10. I shot a screen situation so you could understand the problem.
Below link to update and driver program downloaded: klick
LEO73
<Never a joy>
« Reply #5 on: 15. December 2024, 19:46:23 »
A kindly Hello to Every one and Andreas, Andreas, i Hope It not be a Cinese clone! The logic Board seems like original transceiver pictures ! I found problem about windows not recognised DFU drivers; Previous days I not found P6 jumper(on the logic board) so procedure bootloader update want P6 Jumper closed. So I found P6 jumper and close it. When I punched <Power> and <band - > and plug DFU power to the computer windows recognized DFU driver and I install last Bootloader. After bootloader installation you need to open P6 jumper.
Another problem is about firmware Update, I think about last UHSDR-QRP v.0.6.3 board version (made in 2019 year) have another display model; mine is: HY28B SPI(display controller ILI9325) because I tried all modified firmware by StoryBoy and any one firmware version are not good for my transceiver. In particular, after firmware update, display is fully white! Probability display drivers about there modified firmwares not compatible for my display. Tomorrow I'll try another time tu load the modified firmware. Just one think: I saved my original firmware file version(for my transceiver UHSDR-QRP HF SDR) and this file is ~950 kbyte! It is most big than previous original or modified firmwares. I share it below (firmware version 2.12.2). PS. I bought this transceiver also because modified firmware permitted me to transmit at normal power on 27Mhz (CB bands) with original firmware I can't; I can transmit only at 0.5mW .  Leonardo.
LEO73
<Never a joy>
« Reply #7 on: 16. December 2024, 12:46:41 »
Dear Andreas, I imagined that transmitting with HF transceiver on the CB band was not legal! otherwise how can they sell other CB equipment?  I made a test using original Firmware upgrade and it's work fine! You was right! So problem is modified firmware that not have right library for lastest mounted displaies on the logic board (v.0.6.3) in last 2019 year! I have some skills in programming 8-bit PIC microcontrollers using the C compiler. However, this is a STmicrosistem processor, I don't know which compiler to use to try to make some changes to the code. Is Eclipse (free version) used as a compiler for this project? Do you have a link to download it and a simple tutorial that explains how to use it quickly? My life always seems to be made up of only climbs and obstacles! You can never rest enjoying the work of others! " Never a joy!! "  Leonardo.
| « Last Edit: 16. December 2024, 13:17:18 by leo73 » |
