18. November 2026, 05:05:46
Diskussions- und Newsboard des DARC-Ortsverbandes I40  |  allgemeine Kategorie  |  mcHF Projekt Deutsch / English (here you can discuss everything related to mcHF) (Moderators: DF8OE, DL1PQ)  |  Topic: Seek for know Init Display <- zurück vorwärts ->
   Author  Topic: Seek for know Init Display  (Read 2536 times)
FRS2013
Le savoir ne sert que s'il peut etre partagé
« on: 06. June 2021, 12:01:41 »
I have a RS918 -> BS188 with ILI9341
i seek init this display
i make modification on
ui_lcd_hy28.c
i try write section for this ILI9341
the compilation is good but not init ILI9341
somethink is wrong but why?
i seek more
 ui_lcd_hy28.c.txt
Re:Seek for know Init Display
« Reply #1 on: 06. June 2021, 15:59:54 »
For testing this we would need a device with ILI9341 LCD...I do not think one of the developers do have such a LCD.
In general you can look at arduino drivers and copy init and possibly function which differ to the existent code.
FRS2013
« Reply #2 on: 06. June 2021, 17:42:17 »
Good evening Andrew,
Thank you for your answer
I test and before little by little
I am progressing I have rewritten the lib ILI9341 init
I now have a white screen with reset on my display
so I move slowly
 ui_lcd_hy28.c.new..txt
