allgemeine Kategorie => mcHF Projekt Deutsch / English (here you can discuss everything related to mcHF) => Message started by: FRS2013 on 06. June 2021, 12:01:41
Title: Seek for know Init Display
Post by: FRS2013 on 06. June 2021, 12:01:41
I have a RS918 -> BS188 with ILI9341
i seek init this display
i make modification on
ui_lcd_hy28.c
i try write section for this ILI9341
the compilation is good but not init ILI9341
somethink is wrong but why?
i seek more
Title: Re:Seek for know Init Display
Post by: DF8OE on 06. June 2021, 15:59:54
For testing this we would need a device with ILI9341 LCD...I do not think one of the developers do have such a LCD.
In general you can look at arduino drivers and copy init and possibly function which differ to the existent code.
Post by: FRS2013 on 06. June 2021, 17:42:17
Good evening Andrew,
Thank you for your answer
I test and before little by little
I am progressing I have rewritten the lib ILI9341 init
I now have a white screen with reset on my display
so I move slowly
