29. April 2024, 00:47:46
Diskussions- und Newsboard des DARC-Ortsverbandes I40  |  allgemeine Kategorie  |  mcHF Projekt Deutsch / English (here you can discuss everything related to mcHF) (Moderators: DF8OE, DL1PQ)  |  Topic: Strange nummbers in Switches bias <- zurück vorwärts ->
   Author  Topic: Strange nummbers in Switches bias  (Read 2019 times)
YL3CAAE
« on: 20. May 2018, 20:22:29 »
Hello.
I got strange nummbers in Bias switch B1
1) Turned on RX, volts on all bands exept 20/30m
2) Turned on RX volts on 20/30m
3) Oms when switched off
If i understand correctly B1 need be same as B2,B3, B4
Ilvars
Yl3CAAE
« Last Edit: 20. May 2018, 20:23:02 by YL3CAAE »
DJ3FV
Re:Strange nummbers in Switches bias
« Reply #1 on: 21. May 2018, 05:59:32 »
Hello Ilvars,
it would be helpful if you can give us some details about the rig or version of the mcHF you own and talking about.
73, Uwe
Immanuel Kant
YL3CAAE
« Reply #2 on: 21. May 2018, 07:48:50 »
Hello,
i got v6 board.
Ilvars
Yl3CAAE
« Reply #3 on: 21. May 2018, 08:25:01 »
Its all documented in the original circuit diagram for the 0.6 version:
http://www.m0nka.co.uk/wp-content/uploads/2016/03/mcHF_rf-1.pdf
If you like to improve the BIAS network a bit you can change some values and use the BIAS modification from IZ6MAF:
https://www.amateurfunk-sulingen.de/forum/index.php?board=15;action=display;threadid=910;start=30
« Last Edit: 21. May 2018, 08:25:27 by peter_77 » Logged
YL3CAAE
« Reply #4 on: 21. May 2018, 08:44:10 »
Hello peter,
How i understund Bias circut, on all B1 B2 B3 B4, need be same parametrs, I do not understud why resistance and volts change in B1, all reistors  ( R3a R3b R3c R3d )is same size 100k on all circuts
I ask this becouse i got problem with D3 diode in Antena switch, i change it to new but mybe i got some more broken parts what need change.
« Last Edit: 21. May 2018, 08:46:05 by YL3CAAE » Logged
« Reply #5 on: 21. May 2018, 09:00:48 »
Its a standard voltage divider circuit in the bias network. B1 should not differ from B2 to B4 of course. Its all the same.
If you have such a strange difference here you might have a problem at U1 or probably R1 or C1 and a possible solder bridge or wrong component (U1) ?!
D3 is a whole different story. Here you need to pay attention on RFC2 !
In case you put HF on it and have a bad SWR this coil can burn in seldom circumstances. So make sure you use the correct TDK coils here !
Or... do the radical change and make the relais modification to get rid of all pin diode related issues:
https://www.amateurfunk-sulingen.de/mchf-projekt/modifikationen#start
(RF-04/05-H-029)
There are some photos of this modification here in the forum as well.
« Last Edit: 21. May 2018, 09:04:51 by peter_77 » Logged
YL3CAAE
« Reply #6 on: 21. May 2018, 21:01:05 »
thanks for advise peter
i check r1 and c1 looks it`s ok, ( how i can check in board ) so i order new U1 chip.
About (RF-04/05-H-029) i need little help with  D4 antiparallel diodes, i don`t understand how antiparallel diodes work?
« Reply #7 on: 22. May 2018, 07:21:23 »
If input voltages is increasing and level is getting higher than ~0.6V diodes will shorten them to ground so that no damages in preamp circuit can come up.
