ovi40wiki:wikihowto [20.01.2018 09:32] – [Sprache der Seiteninhalte auswählen] df9ts | ovi40wiki:wikihowto [26.01.2018 09:24] – [OVI40 Wiki - Quick Guide] df9ts | ||
- | ===== OVI40 Wiki - wie geht das? ===== | + | ===== OVI40 Wiki - Quick Guide ===== |
- | [[:rtfm]] | + | === Multi-language Wiki === |
+ | The OVI40 is set up as multi-language Wiki. Each language have their separate | ||
+ | You may select your language here: | ||
+ | While reading a Wiki page you may also use this menu to select the same Wiki page in a different language. If the page exists in another language the language will be in black text. If it does not exist it will be gray. By clicking on a greyed language you may create this page. | ||
+ | You are invited to create pages in your language. Any language missing in the multi-language menu will be added by simple request. | ||
+ | === Automatic Translation === | ||
+ | Certain pages may only exist in certain languages. The Wiki pages in certain languages may contain more informations than in other languages. | ||
+ | For your convenience the OVI40 provides also automatic translation of Wiki pages: | ||
+ | === General Information on the Wiki === | ||
+ | * [[https:// | ||
- | * Dokuwiki Handbuch hier: https:// | ||
- | * Dokuwiki Syntax hier: https:// | ||
- | * Bootnote syntax hier: https:// | ||
- | ==== Sprache der Wikiseite wählen - Wiki-Seite in neuer Sprache erstellen ==== | ||
- | Das Wiki unterstützt Seiten in mehreren Sprachen. Um die Sprache zu ändern auf die Sprachauswahl klicken: | ||
- | **Bestehende Seiten** in anderen Sprachen werden schwarz angezeigt. Durch klicken auf eine in grau angezeigte Sprache wird die Wiki-Seite in dieser Sprache **neu erstellt**. | ||
