Differences
en:uhsdr_dev:win10_toolchain [17.02.2018 18:20] – df9ts | en:uhsdr_dev:win10_toolchain [13.03.2018 09:34] (current) – [Using Git with GNU-MCU-Eclipse] corrected scrambled formatting df9ts_user | ||
Line 1: | Line 1: | ||
- | Based on [[https:// | ||
Summary of [[https:// | Summary of [[https:// | ||
Line 6: | Line 4: | ||
* Java from here [[https:// | * Java from here [[https:// | ||
* If you run 64 bit windows make sure to install 64 bit JRE from here [[https:// | * If you run 64 bit windows make sure to install 64 bit JRE from here [[https:// | ||
- | * Install and test | + | |
* Gnu Arm toolchain from here, Win32 exe [[https:// | * Gnu Arm toolchain from here, Win32 exe [[https:// | ||
- | * Execute. Installs in C:\Program Files (x86)\GNU Tools ARM Embedded\7 2017-q4-major | + | * Execute |
+ | * Installs in C:\Program Files (x86)\GNU Tools ARM Embedded\7 2017-q4-major | ||
* See [[https:// | * See [[https:// | ||
* Download Gnu Arm Windows build tools from here [[https:// | * Download Gnu Arm Windows build tools from here [[https:// | ||
Line 40: | Line 39: | ||
* Will install in C:\Program Files\GNU ARM Eclipse\QEMU\2.8.0-201612271623-dev | * Will install in C:\Program Files\GNU ARM Eclipse\QEMU\2.8.0-201612271623-dev | ||
* Get latest MCU Eclipse from here [[https:// | * Get latest MCU Eclipse from here [[https:// | ||
- | * Extract downloaded zip file to c:\ (otherwise path names may become too long) | + | * Extract downloaded zip file to c: (otherwise path names may become too long) |
* Run GNU MCU Eclipse | * Run GNU MCU Eclipse | ||
* Follow work space preferences " | * Follow work space preferences " | ||
Line 62: | Line 61: | ||
Set active project, check MCU set correctly | Set active project, check MCU set correctly | ||
- | * See https:// | ||
- | * Set/check that active project is correct | ||
- | * Set/check that device is correct | ||
+ | * See [[https:// | ||
+ | * Set/check that active project is correct | ||
+ | * Set/check that device is correct: | ||
+ | * For OVI40 with F7 MCU: Project → Properties → C/C++ Build → Settings → Devices → STM32F767ZI | ||
+ | * For OVI40 with H7 MCU: Project → Properties → C/C++ Build → Settings → Devices → STM32H743ZI | ||
+ | ==== Check for updates ==== | ||
+ | * in Eclipse Help→check for updates | ||
+ | ==== Using Git with GNU-MCU-Eclipse ==== | ||
+ | === Option: Github Desktop === | ||
+ | * Download Github desktop from [[https:// | ||
+ | * Start Github Desktop, enter your Githu username and password, clone repository " | ||
+ | * Optional: create local branch of cloned repo for tests | ||
+ | * In Eclipse, create new workspace pointing to local clone of cloned Github UHSDR repository | ||
+ | * Check Eclipse settings for | ||
+ | * active build config | ||
+ | * MCU device used * … | ||
- | Using Git with GNU-MCU-Eclipse | + | === Option: git commandline === |
- | * Download Github desktop from https://desktop.github.com/ | + | * create directory where UHSDR repository should reside, e.g. d: |
+ | === Import git UHSDR project into Eclipse installation === | ||
+ | * In Eclipse, choose “File→Import”. | ||
+ | * .. then choose “General→Existing Projects into Workspace”. | ||
+ | * Then choose the folder “mchf-eclipse in the path where you just downloaded the zip file as “root-directory” | ||
+ | * The project is now recognized and can be imported * Next: check Eclipse settings | ||
