Differences
en:uhsdr_dev:win10_toolchain [17.02.2018 11:08] – df9ts | en:uhsdr_dev:win10_toolchain [13.03.2018 09:34] (current) – [Using Git with GNU-MCU-Eclipse] corrected scrambled formatting df9ts_user | ||
Line 1: | Line 1: | ||
- | Based on [[https:// | ||
Summary of [[https:// | Summary of [[https:// | ||
* Overview here: [[https:// | * Overview here: [[https:// | ||
* Java from here [[https:// | * Java from here [[https:// | ||
- | | + | * If you run 64 bit windows make sure to install 64 bit JRE from here [[https:// |
* Install and test | * Install and test | ||
* Gnu Arm toolchain from here, Win32 exe [[https:// | * Gnu Arm toolchain from here, Win32 exe [[https:// | ||
- | * Execute. Installs in C:\Program Files (x86)\GNU Tools ARM Embedded\7 2017-q4-major | + | * Execute |
+ | * Installs in C:\Program Files (x86)\GNU Tools ARM Embedded\7 2017-q4-major | ||
* See [[https:// | * See [[https:// | ||
* Download Gnu Arm Windows build tools from here [[https:// | * Download Gnu Arm Windows build tools from here [[https:// | ||
Line 41: | Line 39: | ||
* Will install in C:\Program Files\GNU ARM Eclipse\QEMU\2.8.0-201612271623-dev | * Will install in C:\Program Files\GNU ARM Eclipse\QEMU\2.8.0-201612271623-dev | ||
* Get latest MCU Eclipse from here [[https:// | * Get latest MCU Eclipse from here [[https:// | ||
- | * Extract downloaded zip file to c:\ (otherwise path names may become too long) | + | * Extract downloaded zip file to c: (otherwise path names may become too long) |
* Run GNU MCU Eclipse | * Run GNU MCU Eclipse | ||
* Follow work space preferences " | * Follow work space preferences " | ||
Line 47: | Line 45: | ||
Install PAckages CMSIS | Install PAckages CMSIS | ||
+ | * In Eclipse Help→Install new software, Work with: "GNU MCU Eclipse plug-ins", | ||
+ | * Check that "GNU MCU C/C++ Packs (Experimental)" | ||
+ | * In Eclipse goto C/C++ packs perspective (hover over toolbar icons to find the icon with two boxes in orange yellow) | ||
+ | * In this perspectiv, above middle window, click on the icon with the two yellow arrows, to update the packages definitions from all repositories | ||
+ | * If any warnings that certain packages cannot be downloaded please click " | ||
+ | * When finished, in left window, choose STMMicroelectronics | ||
+ | * Install STM32F7 pack | ||
+ | * Ín left window, click once on STM32F7 series. | ||
+ | * Then select package in middle window | ||
+ | * then above middle window click yellow box icon to install a local copy of the selected package | ||
+ | * You will see status message " | ||
+ | * Install STM32H7 in the same way | ||
+ | Set active project, check MCU set correctly | ||
+ | * See [[https:// | ||
+ | * Set/check that active project is correct | ||
+ | * Set/check that device is correct: | ||
+ | * For OVI40 with F7 MCU: Project → Properties → C/C++ Build → Settings → Devices → STM32F767ZI | ||
+ | * For OVI40 with H7 MCU: Project → Properties → C/C++ Build → Settings → Devices → STM32H743ZI | ||
+ | ==== Check for updates ==== | ||
+ | * in Eclipse Help→check for updates | ||
+ | ==== Using Git with GNU-MCU-Eclipse ==== | ||
+ | === Option: Github Desktop === | ||
+ | * Download Github desktop from [[https:// | ||
+ | * Start Github Desktop, enter your Githu username and password, clone repository " | ||
+ | * Optional: create local branch of cloned repo for tests | ||
+ | * In Eclipse, create new workspace pointing to local clone of cloned Github UHSDR repository | ||
+ | * Check Eclipse settings for | ||
+ | * active build config | ||
+ | * MCU device used * … | ||
+ | === Option: git commandline === | ||
+ | * create directory where UHSDR repository should reside, e.g. d: | ||
+ | === Import git UHSDR project into Eclipse installation === | ||
+ | * In Eclipse, choose “File→Import”. | ||
+ | * .. then choose “General→Existing Projects into Workspace”. | ||
+ | * Then choose the folder “mchf-eclipse in the path where you just downloaded the zip file as “root-directory” | ||
+ | * The project is now recognized and can be imported * Next: check Eclipse settings | ||
