en:uhsdr_dev:uhsdrbuild
Differences
Link to this comparison view
Next revision
Previous revision
en:uhsdr_dev:uhsdrbuild [11.02.2018 11:20] df9ts_useren:uhsdr_dev:uhsdrbuild [15.02.2018 00:03] (current) – [Download new firmwar .bin to OVI40 UI] df9ts_user
Line 27: Line 27:
 Newly built binary fw-ovi40.bin can be found in the eclipse project explorer (left sidebar): mchf-eclipse -> DebugOVI40 -> fw-ovi40.bin Newly built binary fw-ovi40.bin can be found in the eclipse project explorer (left sidebar): mchf-eclipse -> DebugOVI40 -> fw-ovi40.bin
-==== Download new firmwar .bin to OVI40 UI ====+==== Download new firmware .bin to OVI40 UI ====
   * Please refer to [[https://www.amateurfunk-sulingen.de/wiki/doku.php?id=en:uhsdr:uhsdrfw#st-link_v2_firmware_upgrade]]   * Please refer to [[https://www.amateurfunk-sulingen.de/wiki/doku.php?id=en:uhsdr:uhsdrfw#st-link_v2_firmware_upgrade]]
   * UHSDR FW build should run.   * UHSDR FW build should run.
Line 43: Line 43:
 ==== Eclipse user guide ==== ==== Eclipse user guide ====
   * User guide can be found [[https://help.eclipse.org/kepler/index.jsp?topic=%2Forg.eclipse.linuxtools.perf.doc%2FLinux_Tools_Project%2FPERF%2FUser_Guide%2FProfiling-Configuration.html|here]].   * User guide can be found [[https://help.eclipse.org/kepler/index.jsp?topic=%2Forg.eclipse.linuxtools.perf.doc%2FLinux_Tools_Project%2FPERF%2FUser_Guide%2FProfiling-Configuration.html|here]].
-  * Profiling is describede [[http://wiki.eclipse.org/Linux_Tools_Project/Profiling/User_Guide|here]]+  * Profiling is described [[http://wiki.eclipse.org/Linux_Tools_Project/Profiling/User_Guide|here]]
 This covers basic usage as well as advanced tools such as profiling and others. This covers basic usage as well as advanced tools such as profiling and others.
 +==== Debug, tracing, real-time diagnostics ====
 +  * [[http://blog.atollic.com/learn-serial-wire-viewer-debugging-on-cortex-m|nice summary of Cortex M tools here]]
 +  * [[https://gnu-mcu-eclipse.github.io/debug/openocd/|OpenOCD & Eclipse debug step-by-step instructions]]
 +  * {{:en:uhsdr_dev:en.dm00354244.pdf|AN4989 Application note STM32 microcontroller debug toolbox}}
 +  * Concurrent use of ST-Link debugger and SWO Viewer not possible, see [[http://www.openstm32.org/forumthread4122|here]] - but [[https://mcuoneclipse.com/2016/10/17/tutorial-using-single-wire-output-swo-with-arm-cortex-m-and-eclipse/|this]] link states Eclipse support in debugger for SWO?
 +  * J-Link Debug Probe [[:en:uhsdr_dev:segger_j_link|here]]
 ==== Further reading ==== ==== Further reading ====
   * https://www.amateurfunk-sulingen.de/forum/index.php?board=15;action=display;threadid=313;start=0   * https://www.amateurfunk-sulingen.de/forum/index.php?board=15;action=display;threadid=313;start=0
   * https://www.amateurfunk-sulingen.de/forum/index.php?board=15;action=display;threadid=263   * https://www.amateurfunk-sulingen.de/forum/index.php?board=15;action=display;threadid=263
 +  * SWV and SWO and Eclipse explaind [[https://mcuoneclipse.com/2016/10/17/tutorial-using-single-wire-output-swo-with-arm-cortex-m-and-eclipse/| here]]
  • en/uhsdr_dev/uhsdrbuild.txt
  • Last modified: 15.02.2018 00:03
  • by df9ts_user
