Differences
en:uhsdr_dev:segger_j_link [18.02.2018 15:20] – [J-Link support for Option bytes and Lock / Unlock] df9ts | en:uhsdr_dev:segger_j_link [27.02.2018 07:45] – [Segger Real Time Terminal RTT] df9ts_user | ||
Line 1: | Line 1: | ||
- | Segger | + | ==== Segger |
+ | Segger | ||
Segger supports the Cortex M7 SWV interface used on OVI40 UI and offers plug-ins for MCU eclipse. | Segger supports the Cortex M7 SWV interface used on OVI40 UI and offers plug-ins for MCU eclipse. | ||
- | For Debug output Segger offers two options in MCU eclipse: | + | For Debug output Segger offers |
* TRACESWO output as defined by CORTEX M7. This requires a dedicated pin, currently used for M3 pushbutton switch | * TRACESWO output as defined by CORTEX M7. This requires a dedicated pin, currently used for M3 pushbutton switch | ||
- | * Segger Real Time Tracing (RTT) with outputs debug messages in high speed via SWV debug lines (CLK and SWData). No need for an additional line to printout debug messages | + | * [[https:// |
+ | The J-Link makes use of the Cortex-M feature, which allows accessing the memory via the debug interface while the target is running. | ||
+ | How this works in general is described [[https:// | ||
The speed advantage of RTT - according to Segger data - is impressive: | The speed advantage of RTT - according to Segger data - is impressive: | ||
Line 12: | Line 17: | ||
- | ==== Install J-Link Debian SW ==== | + | ==== Install J-Link |
+ | === Debian SW Install | ||
* Download .deb J-Link packages from [[http:// | * Download .deb J-Link packages from [[http:// | ||
Line 21: | Line 28: | ||
- | ==== Install J-Link in GNU MCU Eclipse ==== | + | === Windows SW Install === |
+ | ToDo | ||
+ | ==== Segger J-Link adapter Firmware update ==== | ||
+ | As part of the Segger J-Link SW pack the " | ||
+ | ==== Install | ||
See [[https:// | See [[https:// | ||
- | ==== Install Packs ==== | + | === Install Packs === |
For installing CMSIS packs see [[https:// | For installing CMSIS packs see [[https:// | ||
- | * Download CMSIS packs from Keil, see | + | |
+ | * Download CMSIS packs from Keil, see | ||
* Install local cop of STM32F7 and STM32H7 | * Install local cop of STM32F7 and STM32H7 | ||
+ | === J-Link and Eclipse === | ||
+ | * Describe Eclipse seetings (MCU, CMSIS, probe settings, …) to use J-link probe on Eclipse with uHSDR | ||
+ | ==== Segger Real Time Terminal RTT ==== | ||
+ | * See [[https:// | ||
+ | * See {{: | ||
+ | * [[https:// | ||
+ | - is it really 100 times faster than SWO print and 10.000 times fasster than semi-hosting? | ||
+ | == RTT target code == | ||
+ | The RTT target code is shipped as part of the J-Link Software and Documentation Pack which can be downloaded [[https:// | ||
+ | === Calling SEGGER_RTT print from within interrupts / make it re-entrant === | ||
+ | During RTT output the functions SEGGER_RTT_LOCK() and SEGGER_RTT_UNLOCK() are called by default in RTT, but the function bodies of those functions are empty and need to be implemented according to MCU used and use case. | ||
+ | Please implement | ||
+ | * SEGGER_RTT_LOCK() | ||
+ | * SEGGER_RTT_UNLOCK() | ||
+ | and disable interrupts and threads which might use RTT in SEGGER_RTT_LOCK() and enable them again in SEGGER_RTT_UNLOCK(). | ||
==== J-Link support for Option bytes and Lock / Unlock ==== | ==== J-Link support for Option bytes and Lock / Unlock ==== | ||
+ | Segger provides a "STM32 unlock" | ||
+ | **Note: | ||
+ | Further reading: | ||
+ | * Check Option Byte support on J-Link, see [[https:// | ||
* See [[https:// | * See [[https:// | ||
- | * See 3.12.2 J-Link STM32 Unlock (Command line tool) in {{ : | + | * See 3.12.2 J-Link STM32 Unlock (Command line tool) in {{: |
- | * J-Link adapter seems to support option byte programming via J-link utility and/or J-Flash utility. This is indicated in previous versions of the J-Link or J-Flash user guides, but not in the current ones. See for example section 7.5.1.2 [[http:// | + | |
- | * ToDo: Verify and try out | + | * ToDo: Verify and try out |
+ | ==== Flashing MCU with Segger J-Link ==== | ||
+ | As part of the Segger J-Link SW pack the flash utility " | ||
+ | ==== Get to know J-Link: Converting on-board ST-Link On-Board into J-Link On-Board ==== | ||
+ | * Certain STM32 development boards contain an ST-Link probe. | ||
+ | * For experiments with J-Link (not related to OVI40, but in order to get to know J-Link HW & SW) the on-board ST-Link board of those boars can be converted to J-Link, see [[https:// | ||
+ | * Compatible STM32 that can be re-flashed are listed [[https:// | ||
==== ToDo ==== | ==== ToDo ==== | ||
- | * Describe Eclipse seetings (MCU, CMSIS, probe settings, ...) to use J-link probe on Eclipse with uHSDR | + | |
- | * [[https://os.mbed.com/teams/anyThing-Connected/code/SEGGER_RTT/|Try RTT on UHSDR]] | + | * https://www.segger.com/products/debug-probes/j-link/models/other-j-links/st-link-on-board/Checkout [[https:// |
- | * Check Option Byte support | + | |
- | * Checkout [[https:// | + | |
==== Further Reading ==== | ==== Further Reading ==== | ||
